Carrier Control Board Won't Send 24 V To Outside Contactor - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-27-2012, 03:32 PM   #16
Originally Posted by beenthere View Post
Did you try jumping the red and yellow wires at the thermostat. m ay be your thermostat wires are broken.
Good idea....Will try that next
bcarl2u is offline   Reply With Quote
Old 06-27-2012, 03:39 PM   #17
An old Tradesmen
Rewards Points: 6,850
Then it sounds like you have a problem with your wires themselves.
The wire from the condenser that connects to the Y terminal of the furnace. put it on the R terminal of the furnace. then either put the panel back on and turn the power on to the furnace, or turn on the power, and hold the safety switch in, and see if the condenser runs then.
Old 06-27-2012, 07:25 PM   #18
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Pull stat off of wall and twist your red/yellow and green wires together and see if blower in basement and outside unit come on.
Im off to a bar with 2 ac's down and a bunch of unhappy drunks!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
New control board or fix it? Bobeht HVAC 26 01-18-2012 03:03 PM
Am. Std. Furnace Control Board Rusty Nail HVAC 0 05-20-2011 10:55 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Carrier gurus, I need help wiring Infinity Control nyrangers HVAC 0 10-15-2010 11:51 AM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 09:33 PM
