Carrier Control Board Won't Send 24 V To Outside Contactor - HVAC - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 03:37 PM   #1
Question
carrier control board won't send 24 v to outside contactor
Carrier hk42fz009 keeps flashing...blower runs constantly ...replaced thermostat then board...same blinking issue...switched leads from transformer ...no help...push contactor in..unit runs...cannot figure out why I'm not getting 24 to coil..hv 24 goin to board ...but not out to coil...confused
bcarl2u is offline   Reply With Quote
Old 06-25-2012, 03:58 PM   #2
JJboy's Avatar
check the wires
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-25-2012, 04:49 PM   #3
Checked checked and rechecked wiring from schematic on unit and new control board
Old 06-25-2012, 05:19 PM   #4
JJboy's Avatar
Can you explain better your problem??
blower runs constantly????
? Fan on or Fan off switch / Call for cooling
same blinking issue????? Which error code
..... contactor low voltage at the condenser right?
Why did you change thermostat and board????
Old 06-25-2012, 05:34 PM   #5
biggles's Avatar
remove the stat off the subbase(shut the line power off out on the condenser) FAN OFF or ON? at the subbase jump R to Y then check contactor outside?should be pulled in.as you jump and un jump R/Y that contactor should bang in and out...get a pair of eyes out there to yell out whats happening.if nothing leave the stat off the wall jump the board at R/Y see what happens if it pulls in there is an open wire between the furnace and the stat.that constant fan remove G first on the subbase? then go down to the furnace board and remove G either shuld drop the fan out?lets here back...
Old 06-25-2012, 06:11 PM   #6
An old Tradesmen
Rewards Points: 6,148
The board doesn't send power to the outdoor unit. the thermostat does.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
hvactech126 (06-25-2012), plummen (06-25-2012)
Old 06-26-2012, 12:02 AM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Do you have 24v coming back from the stat to call for condensor to come on?
If your furnace has a terminal board/junction block check for 24v between y and common.
If the low voltage wires are just spliced/dangling check for 24v between your yellow or blue depending on how its wired and the common side of the low voltage wiring.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 06-27-2012, 03:13 PM   #8
No voltage on board from Y to C when energized ...none nothing on any terminals when therm is off....have 27 goin to board ...blower runs...nothin else happens ...tried another. therm as well...light keeps flashing as if reversed polarity ...don't see it
Old 06-27-2012, 03:15 PM   #9
No volt reading on board whether therm is calling or not
Old 06-27-2012, 03:17 PM   #10
I'm not gettin anything on board from therm..blower just runs ..no Y to C either
Old 06-27-2012, 03:19 PM   #11
Board doesn't seem to receive anything from therm...tried two different thermostats
Old 06-27-2012, 03:44 PM   #12
Runs on auto and on constant
nondescript ..I believe reversed polarity
no reading from thermostats wire on board
Old 06-27-2012, 04:13 PM   #13
tried....unable to jump..r to y or anything....contactor only closes when
Pushed in manually
Old 06-27-2012, 04:25 PM   #14
An old Tradesmen
Did you try jumping the red and yellow wires at the thermostat. m ay be your thermostat wires are broken.
Old 06-27-2012, 04:29 PM   #15
Pushed in manually
New control board or fix it? Bobeht HVAC 26 01-18-2012 04:03 PM
Am. Std. Furnace Control Board Rusty Nail HVAC 0 05-20-2011 11:55 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Carrier gurus, I need help wiring Infinity Control nyrangers HVAC 0 10-15-2010 12:51 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
