Carrier Control Board - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 09:44 AM   #1
I'm Your Huckleberry
Rewards Points: 2,270
Cool and fan work. In heating mode no power to inducer terminal. Checked continuity of inducer to make sure it was good and it was. Board's been changed out twice in the last few months by another company but was during cooling season so they either didn't check heat or knew it wasn't working.
Fuse was blown but did not blow once replaced.
Same thing, bad board?
Doc Holliday is offline   Reply With Quote
Old 11-01-2011, 10:00 AM   #2
Rewards Points: 6,652
Yes, if they did not ground themselves when replacing, the tech could of killed it.
Old 11-01-2011, 10:05 AM   #3
Thanks. I'm just wondering if the current replacement without heat is the correct one and is the inducer over amping and taking out the board. But heat would've had to have worked to begin with for the inducer to take out the board so..
Board isn't cheap. Inducer assembly is even more than the board. Might just push for a new furnace.
Thanks Gregzoll.
Old 11-01-2011, 10:20 AM   #4
Depending on how bad of shape the whole unit is, and age, you can only duct tape & bailing wire something only so long, to keep them running.
Old 11-01-2011, 10:25 AM   #5
I wouldn't say it's in bad shape, it's just old. The home owners, through their home warranty, have a new evaporator and a new condenser. When the condenser was replaced is when it was figured that the board was bad and that was replaced. A few days later the board went bad and again was replaced and now, two months later, it's not sending power to the inducer and without the inducer, as we all know, no heat period.
Never seen a board not send power to an inducer before. Odd.
I have pics. Terrible clarity but I have a few.
Old 11-01-2011, 10:27 AM   #6
Bad wire connection. Wiring does corrode over time.
Old 11-01-2011, 10:30 AM   #7
One small black wire on the far left neutral and the one small black wire on the "INDucer" terminal, those being the inducer wires. Nothing (voltage) at terminals while on call for heat by way of stat and by way of jumping at board. I wonder if I could use the "HUMidifier" terminal? Anyone?
Old 11-01-2011, 10:34 AM   #8
Problem is doc, is there voltage there when there is a call for heat, or all the time? I personally would check with the manufacturer directions, or wait for someone else to chime in. If you are not getting voltage to that point on the board, I would look for burnt lines on the back of the board, or burnt electronic parts along the path to that terminal.
Old 11-01-2011, 10:48 AM   #9
No power at any time. I just got off the phone with Carrier Technical Support. They said the same thing, bad board.
Old 11-01-2011, 10:50 AM   #10
No power to inducer at any time, while on call for heat or not, rather than no power anywhere I should say.
Old 11-01-2011, 02:39 PM   #11
An old Tradesmen
Rewards Points: 7,816
Make sure the board has a proper low voltage ground.
The Following User Says Thank You to beenthere For This Useful Post:
Doc Holliday (11-01-2011)
Old 11-01-2011, 05:46 PM   #12
You think a lack of 24 volt ground can take it out?
Old 11-01-2011, 05:49 PM   #13
I can't exactly recall but it looks as if it has one. Can't say how well it's connected either. Thanks BT, I'll check it out.
Old 11-01-2011, 09:39 PM   #14
AKA HVACTECHFW
Rewards Points: 1,208
that doesnt look like an oem carrier control board. But I can't see it that well, could just be my eyes paying tricks on me.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 11-01-2011, 10:48 PM   #15
I don't think it's an oem either. Carrier themsleves does not carry a general replacement.
The board has been changed out twice already. This board was laying near the furnace.
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 10:50 PM
Draft Inducer control board replacement daney21 HVAC 9 01-17-2012 01:21 AM
WOW, this control board is cooked! bigscooter HVAC 26 12-07-2011 11:46 AM
How to protect AC control board from blowing during thunderstorm/lightning ? anku HVAC 23 07-09-2009 09:20 AM
Blower control board mlmaher HVAC 1 11-24-2007 01:39 PM
