Old 11-20-2009, 11:19 AM   #1
Carrier Condensation Leak
Just had my furnace Carrier 58XSC100-101JG repaired and paid $600 to have the control board replaced. The board was burned up and the pro said it was due to a condensation leak dripping down and eventually reaching the control board. He showed me the leak. It was where the PVC exhaust pipe mated with the exhaust fan assembly. Looking at it today the leak is still there. There is a rubber coupler that clamps onto the unit exhaust fan assembly ~3in diameter (OD) and then clamps to the PVC exhaust pipe that is 2" PVC. (this is a 2in - 3in coupler to the 3in PVC that vents to the outside) The PVC OD is actually 2 3/4in or so. The rubber coupler clamp on the pvc end is tightened all the way so the seal is poor. Thus it still leaks. It seams to me that the Pro I paid should have noticed the mismatch of pipe diameters and the poor seal. The average hardware store has nothing in 3in OD. Does anyone know the proper mating arrangement / parts for coupling the Exhaust fan to PVC exhaust vent piping?
joehomeowner is offline   Reply With Quote
Old 11-20-2009, 07:30 PM   #2
Did you call the company back and complain? They might just eat the return call ,doesn't hurt to ask.
Old 11-20-2009, 07:39 PM   #3
An old Tradesmen
Call them back. And or the installing company.
Old 11-20-2009, 08:46 PM   #4
Houston204's Avatar
2 3/4" OD is 2 1/2 " pipe. A 2 1/2" x 2" PVC reducer is hard to find.
Like Marty and Beenthere have stated the $600 repair should have included this.
Houston204 is offline   Reply With Quote
Old 11-21-2009, 10:17 AM   #5
Thanks, I know the guy should have done it right. However this is the way the unit was installed so he would probably charge to replace the coupler and maybe say that's a plumbers job.
Attached is a picture. The leak is at the red arrow. I have added a layer of rubber under the clamp so there is additional clamping force. It's holding for now. The condensation pools right at the pvc reducer. Is the 3" vent pipe installed correctly? Should the reducer be outside the furnace? How do I find the right installation parts to couple the furnace (Black 3"OD) to the PVC and account for the differences in the OD - sizing etc..??
More On This Topic
How to Repair PVC Pipe
How to Repair PVC Pipe by Expert Village
Sometimes you’ll have PVC that’s broken under the ground, especially in an irrigation system. And it’s very simple to fix - it’s very cheap, too. What you need to do is identify where the break is - we’re going to imagine... Read More »
Hi this is Fernando we are here with Expert Village now we are going over cutting the pvc piping and what we have here is the pipe pvc cutters which are a excellent tool to have if budget constraint you not allowing to have it then I suggest that you go... Read More »
Troubleshooting Fluid Leaks
Troubleshooting Fluid Leaks by Expert Village
Hi! This is John on behalf of expertvillage.com. In this video clip, I will be talking about trouble shooting liquids found underneath your car. If you take a look at this liquid on the floor, which is from under my car, if I touch it and look at my... Read More »
Hi! I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods and we're going to do some work for you today on Expert Village. Dave is installing muffler clamps to hold the tail pipe into the muffler. They should be tight... Read More »
Not only is mold unsightly, it can cause health problems. Mold grows in humid or damp areas of your house and will continue to grow unless removed. After removing the mold, you can prevent it from growing back with a few simple steps. Here are a few tips... Read More »
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
A Leak and Why No Condensation from AC? sneaky_pete HVAC 3 08-19-2008 06:55 PM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 09:18 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing 4 05-06-2008 02:18 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
