Carrier Comfort 92 Pressure Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 07:19 PM   #1
Carrier Comfort 92 pressure switch
What pressure is the pressure switch measuring, lloks like a pressure difference between the burner and somewhere in the inducer. And how does this relate to the condensation trap
superape is offline   Reply With Quote
Old 12-04-2011, 07:54 PM   #2
HVAC Tech/ Browns Fan
If trap gets plugged up. It will cause draft motor to get full of water and not let it go full speed. The pressure switch gets sucked in when draft motor is clean and clear.
Tator1076 is offline   Reply With Quote
Old 12-04-2011, 08:07 PM   #3
Thanks Tator
Tags
carrier , condensation drain , pressure switch
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace pressure switch issue darylzero HVAC 28 11-19-2011 07:52 PM
Pressure Switch Question loftezy HVAC 11 04-12-2011 05:57 PM
Well Pump pressure switch help needed. slabm7 Electrical 20 11-03-2010 06:56 PM
Bad pressure switch? gshock HVAC 3 11-13-2007 08:15 PM
