Carrier Comfort 92 LED Code 31 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 02:13 PM   #1
Carrier Comfort 92 LED code 31
I am receiving error code 31 on my new Carrier Comfort 92. Background; I am doing demolition in the house. A condensation pump was installed with the line running upstairs because there is no drain in the basement. I cut the condensation line for the demo and put the tube in a large mason jar in the basement. The jar overflowed. I took the tube out of the jar and cleared the line, but I still get error code 31 after turning power off and on.
superape is offline   Reply With Quote
Old 12-04-2011, 02:55 PM   #2
HVAC Tech/ Browns Fan
on the door panel will tell you whats the code. But sound like the tube going to burner box is plugged. Unplug it and restart it.
Tator1076 is offline   Reply With Quote
The Following User Says Thank You to Tator1076 For This Useful Post:
yuri (12-04-2011)
Old 12-04-2011, 06:07 PM   #3
do you mean the air intake for the burner?
carrier , code 31 , comfort 92 , condensation , pressure switch
code 33 carrier 58mca furnace kevin hunger HVAC 10 01-06-2014 11:29 AM
Carrier code 31 MckinneyCodeman HVAC 8 10-29-2011 05:41 PM
Carrier code 31, post duct cleaning. Dacuer HVAC 2 10-18-2011 04:44 PM
Carrier Error Code 33 russell124 HVAC 4 12-04-2010 07:19 PM
Carrier 58MXA Code 31 Problem MikeZ HVAC 8 01-12-2010 06:32 AM
