Carrier Code 31 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2011, 01:55 PM   #1
Unhappy
Carrier code 31
I replaced the control board on my Carrier unit before the summer hit because I was told it had an intermittent short in it on a previous service call. It would quit working under extreme cold and mysteriously start back up hours and sometimes days later. After I replaced the board we made it through the summer fine. I am now trying to make sure all is well for the winter. I get a code "31" flashing when I try to get the heat to come on. I pulled my Norton hot surface igniter and it ohmed at 135. I also pulled the pressure valve from the other unit and swapped them. The other unit still works fine. I noticed that the small fan on the other (working) unit comes on about the same time the igniter heats up and the gas kicks in. Neither of those things happen on the unit that flashes the code "31". The blower comes and it blows cold air, but no ignition or heat. Can anyone help with this?
MckinneyCodeman is offline   Reply With Quote
Old 10-29-2011, 02:10 PM   #2
raylo32's Avatar
Rewards Points: 1,254
Deja vu all over again...
Carrier Furnace codes
raylo32 is offline   Reply With Quote
Old 10-29-2011, 03:11 PM   #3
I know what the codes mean. I have them right in front of me. I am trying to figure out why I am getting the code. I have already eliminated the pressure switch. I have already pulled the vent line loose. I have reset all the overtemp switches. The board was replaced this year. I am trying to figure out why the inducer fan isn't coming on.
Old 10-29-2011, 03:15 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
you need to check for voltage to the inducer. If no voltage with a call for heat then it is the board, if voltage the the inducer does not run it could be the capacitor (90 % eff. furnaces use a cap , 80% do not typically) or a bad motor.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-29-2011, 03:42 PM   #5
Just to be sure I am looking at the right motor...the inducer has the small fan on it, right? Right by the pressure switch? The only capacitor I can find on the unit is at the blower. If I am looking at the right motor it should have 120v a/c?
Old 10-29-2011, 03:58 PM   #6
AKA HVACTECHFW
yes, small motor with pressure switch close by. yes, 120VAC. does the furnace use PVC or Metal Pipe for the flue?
IT IS WHAT IT IS
Old 10-29-2011, 05:09 PM   #7
Metal pipe. I took the connector loose to the inducter fan and did not get 120v. Did I get a bad board?
Old 10-29-2011, 05:36 PM   #8
HvacWiz's Avatar
Rewards Points: 252
Is there anthor circuit board behind the pressure switch?
HvacWiz is offline   Reply With Quote
Old 10-29-2011, 05:41 PM   #9
AKA HVACTECHFW
please answer this question as some of the older units had this other board.
IT IS WHAT IT IS
Carrier code 31, post duct cleaning. Dacuer HVAC 2 10-18-2011 04:44 PM
Carrier Furnace code 12 WhataboutBob HVAC 3 03-17-2011 08:19 PM
Carrier Error Code 33 russell124 HVAC 4 12-04-2010 07:19 PM
Carrier 58MXA Code 31 Problem MikeZ HVAC 8 01-12-2010 06:32 AM
code 31 Carrier 58MXA Mr. Break It HVAC 1 01-02-2008 10:24 AM
