Carrier Cobra Circa 1996 W/ Electronic Ignition - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 08:46 AM   #1
Wink
Carrier Cobra circa 1996 w/ electronic ignition
Hi All,
We had heat (alot of heat!) up until mid afternoon yesterday and blower works without heat today. We have power to the unit, we have gas to the unit (at least gas fireplace and stove work), tried recyling the unit at the circuit breaker and it appeared to be attepting to light without success. Have never worked with furnace or gas before and am not really excited about starting. Really want to confirm my suspicions that the electronic igniter is the likely culprit (and a typical retail cost for fixing it) before i bring someone out to look at it. I am new to my neighborhood (Norfolk Va) and do not have established ties with any service company and am more afraid of shylocks than cold .
thanx in advance
ChuckT
ChuckT is offline   Reply With Quote
Old 11-30-2008, 11:15 AM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi ChuckT
The first question that we will need an answer too, when you say the furnace tries to light do you see an orange glow? Second question, does the blower run continuously when the thermostat is calling for heat. If the answer to the first question is yes, then the ignitor is fine. If the answer to the second question is yes, you could have an open limit. If you could be a bit more detailed about the series of events starting from turning the thermostat to heat, I bet you I can nail it.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 11-30-2008, 04:56 PM   #3
Its the Opposite
No glow and the blower does not stay on unless I switch to manual
Old 11-03-2011, 02:39 PM   #4
1996 Cobra furnace. Unit works sometimes. Tried 3 new thermostats. New board, new ignitor. Unit will work after a reset then won't recycle later. Keeps trying to light then code 14. Normally occurs in early morning hours. I've had service tech's out 8 times (refuse to come any more, said all is well). Please help
kajunharry is offline   Reply With Quote
Old 11-03-2011, 07:36 PM   #5
Rewards Points: 1,574
Kajun,
Start your own post. It gets too confusing following two different people's posts.
bob22 is online now   Reply With Quote
Tags
carrier , electronic ignition , gas furnace
This may help someone with carrier ignition problems AweMan HVAC 15 02-09-2009 02:20 PM
Problems with Carrier Furnace circa 1990 Blue2 HVAC 4 11-27-2008 07:32 PM
Electronic ignition furnace question rcossebo HVAC 4 11-23-2008 02:02 PM
Electronic Ignition Furnace will not stay burning Drennen HVAC 3 12-29-2007 02:20 AM
Gas Stove top with electronic ignition mycin17 General DIY Discussions 1 02-11-2006 09:53 AM
