Carrier Blown 3 Amp Fuse Troubleshoot - HVAC - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 08:07 PM   #1
Unhappy
Carrier blown 3 amp fuse troubleshoot
I have been having a problem with the control board fuse blowing out on an older Carrier furnace with standing pilot. furnace model# 58GFA120-LC. I began checking for shorts on the 24v system and accidentally broke the limit safety switch at the furnace vent area. I suspect that this switch was bad to begin with because the draft inducer ran fine with the switch wires disconnected but naturally the gas valve didn't operate. When the switch was connected, the draft inducer airflow was surging just before the fuse would blow. Would a bad safety switch cause the airflow to surge before blowing the fuse?
sportster_16301 is offline   Reply With Quote
Old 01-07-2011, 05:15 AM   #2
An old Tradesmen
Rewards Points: 6,156
That spill switch had no effect on the air flow.
Old 01-07-2011, 08:24 AM   #3
still confused
Do you know what would cause it then?
Old 01-07-2011, 03:49 PM   #4
An old Tradesmen
Could be the board has a short in it.
Check the voltage going to the inducer. See if its surging. or if the inducer itself is having a problem.
Check your other low voltage wiring to see if any connections from the thermostat are loose.
A surging inducer is not a common thing.
The Following User Says Thank You to beenthere For This Useful Post:
sportster_16301 (01-07-2011)
Old 01-07-2011, 08:14 PM   #5
solved
The problem was a bad gas valve. After disconnecting the leads to it the furnace ran fine but wouldn't light of course so I took the chance and bought a new valve. Presto, it's fixed.
Tags
blowing , carrier , fuse , surging , switch
Blown 5 amp fuse on Carrier System chalkstar HVAC 9 07-23-2014 12:18 AM
Carrier Control Board Fuse Blows kdljet HVAC 5 03-11-2009 10:20 PM
Carrier Model 58CTA110 Blown Fuse Jmcoglio HVAC 2 12-29-2008 12:31 PM
Carrier 8000TS Control Bd Fuse blows EAP HVAC 2 08-28-2008 09:07 PM
Blown fuse in Control Panel of Carrier Heater jacksup HVAC 3 02-26-2008 06:02 PM
