Carrier Air Handler Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 10:34 AM   #1
I have installed a Carrier fv4c air handler and 24abc636a003 condenser and am trying to wire them up to a honeywell thermostat. Does this wiring look correct?
Patrick3152 is offline   Reply With Quote
Old 03-08-2013, 10:35 AM   #2
And this
And this
Old 03-08-2013, 10:44 AM   #3
Originally Posted by Patrick3152 View Post
And this
Looks good to me
JScotty is offline   Reply With Quote
Old 03-08-2013, 10:46 AM   #4
Willing to listen
Rewards Points: 219
I'm not super familiar with the Carrier Air Handler, but am wondering why you aren't wired to the Y1 terminal on it's control board?
(although it should not matter since you have the Y1 to the OD unit on the same terminal as the Y1 from the Tstat)
Done That is offline   Reply With Quote
Old 03-08-2013, 10:48 AM   #5
Originally Posted by JScotty View Post
Looks good to me
Actually after giving it a 2nd look the yellow wire from the stat & the red wire to the cond unit look like they should be moved one space up to Y1 in the furnace. Can't really see what the terminal they're in is labeled, but they should be in Y1, although often you'll see those wires not even connected at the terminal block, but just wire nutted together. So not sure if it will actually matter.
Old 03-08-2013, 11:22 AM   #6
Sparks
I turned on the breaker at the main panel. I turned on the disconnect at the unit. There was an immediate humming sound and the fan started spinning up. After about ten seconds of trying to figure out why the fan was coming on already a huge arc happened behind the fan. I'm assuming coming from the heater strip. This happened for a split second before I hit the disconnect and it stopped. I have a pro coming out, but I'm curious as to what happened!
I'm not an ac guy, but I did build my entire house, wired it up, etc, so I'm not totally clueless.
Old 03-08-2013, 11:49 AM   #7
Willing to listen
Rewards Points: 219
This is all new equipment or has it been run before?
Was the thermostat installed?
Old 03-08-2013, 12:00 PM   #8
HVAC Tech/Owner
Rewards Points: 604
No, its a variable speed airhandler and it is wired to the Y/Y2 terminal which is correct.
I would lean toward the thermostat isn't set up for AC/electric heat
Technow is offline   Reply With Quote
The Following User Says Thank You to Technow For This Useful Post:
hvactech126 (03-08-2013)
Old 03-08-2013, 12:01 PM   #9
Ac
This equipment was installed and removed before it was ever run. A friend sold it to me (he is a pro).
Old 03-08-2013, 04:33 PM   #10
Fixed it!
I removed the electric heater strip and found a piece of foil tape on the heater coils. Also I was missing a jumper from r to dh in the air handler which put the unit into dehumidify mode and turned on the heater. When I powered it up the heater kicked on and it did not like that tape!
Do I really need the air handler filter? Flt_Simulation HVAC 2 09-17-2012 11:38 AM
Wiring float switch to air handler Terrw58 HVAC 1 05-13-2012 09:13 PM
Return Vents and Air Handler Question hifiman HVAC 7 04-27-2012 07:44 AM
T-Stat Wiring - Lux TX9100e replaces Honeywell T8411R for Carrier Heat Pump/Cooling 99Problems HVAC 1 08-19-2010 02:44 PM
SPace Pak Air Handler Wiring Question--208-230/60/1 metal121 HVAC 5 05-07-2009 06:52 AM
