Carrier 9200 Won't Run
Hi,
I Have 2 Carrier 9200 Weatrhermakers. One Upstairs And One Down. The Upstairs One Will Not Turn On, Blow Air, Run Fan, Heat Or Cool. Nothing. I Checked The Power To Unit And The Utility Outlet Installed Near Unit Has Good Power To It. The Little Switch Is On In The Unit, The 3 Amp Fuse Is Good. I See What Looks Like A Thermal Fuse (white Ceramic Block With Two Wires), And On The Unit It Also Says Something About Another Shutoff Safety. Help! We Are One Hour From Anything And If I Can Fix It Myself, I Definitely Want To! Thanks For Any Help!
David
