Carrier 9200 Furnace Water Leak - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2009, 05:02 PM   #1
maryjo
carrier 9200 furnace water leak
Our 9200 carrier weather maker furnace has puddles of water around the base of the furnace. It looks like it's leaking under the inducer housing drain tube is what the manual seems to show. Can these hoses be replaced easily? We don't find much detail in the manual for ordering parts by diagram.
maryjo is offline   Reply With Quote
Old 11-26-2009, 05:09 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,826
You have to buy an EXPENSIVE kit/package of hoses with all of them in one bag from Carrier.
Old 11-26-2009, 06:02 PM   #3
maryjo
How expensive is EXPENSIVE? As much as having a professional come and do the repair?? We are going to try to flush the hoses with Propelyne Glycol as described in the manual when we can get to a place that has just that instead of the auto antifreeze.
Old 11-26-2009, 06:18 PM   #4
Hvac Pro
yuri's Avatar
Not sure about the glycol comment. That funny accordion looking hose usually cracks at the accordion folds. Check them to see if that is the leak. Last time I checked the kit was around $80-100 my cost 3yrs ago and I get the Pro discount. One of our posters HAir Direct may be able to order it for you and get a decent price. Glycol is used to winterize the condensate trap if the unit is in a cottage etc. Read the thread below yours.
Old 11-26-2009, 06:55 PM   #5
maryjo
Thanks for the information. I suspected the hoses were leaking at those accordion folds. Would it be possible to replace the hoses with generic hose or does it have to be heat resistant or for some reason accordion pleated? We have aquarium hose that's the right diameter.
Old 11-26-2009, 06:58 PM   #6
Hvac Pro
yuri's Avatar
It is very difficult to keep that hose from kinking. If you can great! If it kinks then the water backs up in the ventor fan and the furnace shuts down. Not heat resistant required. Marvel of engineering those hoses. add .com to our friend.
Detecting Water Leak in Back Yard melmjd Plumbing 2 11-14-2011 11:56 AM
Carrier weather maker 9200 furnace NO 24 volts mmtuxedo HVAC 1 09-25-2009 06:49 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Sealed Combustion Furnace and Tank Hot Water Heater Yippee HVAC 6 06-16-2009 12:32 PM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
