Carrier 9200 Furnace Problem, Help! - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 02:17 PM   #16
Originally Posted by yuri View Post
you cannot replace the "bearing" in that motor as it has none. has a sleeve which the motor shaft spins on. if the motor has the 3 mounting legs welded to it then you also need to get a belly band adaptor with mounts for the new motor and order a capacitor fore the new motor 2.
sadly as i feared, the capacitor didnt do the job. Im guessing my next move is to order a new motor? im going to start looking around online but im at a loss for the moment
DariusRBKS is offline   Reply With Quote
Old 03-11-2013, 02:49 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 116
check the voltage to the motor first. very rare but the board may not be sending 120 volts. remove the wire where it says Heat tap on the board and check from there to ground or neutral after the burner has run for 2 minutes. has a 90 second time delay when it starts. I would remove the fan first and see if you can remove the motor and wheel. it may be seized on and we have special pullers to remove it w/o damaging it. if it won't come loose easily then I would take the whole works to an electric motor shop.
Old 03-13-2013, 04:34 PM   #18
the board shot down fine. ive started the removal process of the blower, i took out the board, and safely removed the condenser, as well as the other wiring around the blower. Tomorrow i am planning on removing the rest and i have a local shop to take to motor to, is there anything in particular that i should watch out for in removing the blower, or anything i should inspect on the motor while i have it out?
Old 03-13-2013, 04:47 PM   #19
try the capacitor, it is there to get the motor up to the proper speed and give it horsepower. w/o it the motor overheats. google PSC motor if you want to know how it works.
Yeah it's always better to try the capacitor first since it's a very cheap part. However from his description I don't think that's it. If the motor was overheating due to a bad capacitor it would stop humming. The fact that it stopped but continues to hum tells me the motor is locked up & still trying to spin. Usually when they overheat they stop making noise.
JScotty is offline   Reply With Quote
Old 03-13-2013, 05:24 PM   #20
Hvac Pro
yuri's Avatar
Rewards Points: 116
You can crawl in there on your back and look up at the secondary heat exchanger for wet marks or rust. They had a lot of problems with them failing and a class action lawsuit so Carrier will replace it. Need to get a authorized Carrier dealer to look at it at that point and verify it is leaking and do the work. If it is very dirty you can try clean it also.
Tags
blower motor
I have a carrier 9200 furnace and the pilot light is out. its just blowing cold air tom sebastian Appliances 1 03-17-2012 12:29 PM
Carrier 58 RAV Furnace Problem ? fixit99 HVAC 11 12-30-2011 06:57 PM
Carrier furnace problem. Pilot lights, no burner Donut HVAC 1 02-09-2011 08:07 PM
Carrier Weathermaker 9200 problem lemsouthside HVAC 3 02-06-2011 07:00 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
