Carrier 9200 Furnace - Drain Line? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 03:23 PM   #1
Question
I opened the cabinet to our Carrier Weathermaker 9200 and found a big area of rust inside and around the furnace. The black tube in the attached picture somehow became unattached. This line has an attachment fitting at the end of it. I can't find any obvious place where it connects. One option might be that it connects to a line out of the hole above it in the picture and out to the floor drain? Any help is appreciated.
rimoto is offline   Reply With Quote
Old 08-21-2011, 06:48 PM   #2
An old Tradesmen
Rewards Points: 7,794
That one should have a plug in it. Its only used when the furnace is installed in a horizontal application.
The Following User Says Thank You to beenthere For This Useful Post:
rimoto (08-22-2011)
Old 08-21-2011, 09:47 PM   #3
Thanks for this reply. I tested the the tube by filling it with water and it was indeed plugged at that end.
Old 08-21-2011, 10:31 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
most likely you have a leak at the outlet of the draft motor where the 2" pvc pipe attaches. It looks like you are missing a clamp on the pipe. (above the arrow in your picture.)
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-21-2011, 11:00 PM   #5
Just to be sure, you're referring to this one in the picture below? The rust stain sure looks it's from a leak around there. Please confirm and I'll go buy another 2" clamp tomorrow.
Old 08-22-2011, 04:46 PM   #6
AKA HVACTECHFW
Yes, that is what I was referring to.
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
rimoto (08-22-2011)
Old 08-23-2011, 03:39 AM   #7
jackpercy57 is offline   Reply With Quote
The Following User Says Thank You to jackpercy57 For This Useful Post:
rimoto (08-23-2011)
Old 08-23-2011, 07:12 AM   #8
[quote=jackpercy57;713370]That one should have a plug in it. Its only used when the furnace is installed in a horizontal application.
Thanks. I can confirm that the tube has a plug in it and that the leak is not from that tube.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Water heater drain pan line Bigmike33 Plumbing 1 09-22-2010 08:29 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
90% Furnace, AC Drain, & Secondary drain pan. Hook all together? hartkem HVAC 25 11-18-2008 12:34 AM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
