Carrier 9200 Blower Fried? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 09:19 PM   #1
My furnace made a high pitched noise and a burning fan belt smell last night so turned if off.
This morning I opened it up and found the the air filter had been sucked into the squirrel cage and jammed it.
I cleared the jammed cage and restarted the furnace. It seemed to start up just fine until the fan motor clicked on. There was the high pitched sound when the motor clicked on plus the smell and the cage looked like it was trying to turn, but only barely...I am hoping maybe the set screw was broken? Or worse the motor burned out... Is it the motor? If so, is this a job I could do?
Any help and advice would be greatly appreciated. Thanks.
Treatgang is offline   Reply With Quote
Old 11-03-2011, 10:21 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
motor blown. You can do it yourself but you'll have to get the exact same hp and rpm motor and you have to make sure it's a blower motor and not a condenser fan motor.
Doc Holliday is offline   Reply With Quote
Old 11-03-2011, 10:33 PM   #3
Motor
Thanks Doc...I really appreciate the quick response. Any suggestions on where to look for said motor??? Online or local?
Gratefully, Treatgang
Old 11-03-2011, 11:00 PM   #4
Grainger.com
Master of Cold is offline   Reply With Quote
Old 11-03-2011, 11:21 PM   #5
Rewards Points: 490
Check the Fasco catalog
http://www.fasco.com/prodcat.asp
diyorpay is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Carrier Weathermaker 9200 blower problems preacher01 HVAC 4 06-01-2012 07:24 AM
Carrier Weathermaker 9200 - Blower not turning on. bvijay HVAC 7 08-15-2011 08:04 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
Problem with Carrier Weathermaker 9200 Chipley HVAC 12 12-16-2008 01:44 PM
