Carrier 8000ST - HVAC - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 05:03 PM   #1
Carrier 8000ST
Furnance won't start....Check the ignitor, ohm reading still good. Error code indicate 34.
What maybe the problem..?
anhtwan is offline   Reply With Quote
Old 10-19-2011, 06:53 PM   #2
Houston204's Avatar
Rewards Points: 556
What are the first 5 digits of the model number?
When you reset it and watch the furnace try to start, do you see the ignitor glow?
Ignitors can usually be checked without an ohm meter. What did it read?
Houston204 is offline   Reply With Quote
Old 10-20-2011, 09:47 AM   #3
Carrier 8000ST. Error code 34
Hello.
Thanks for relying Houston204...Model: 58TUA080-4...Serial: 2402A72918. The ignitor did not glow at all. I check the ohm..It is still at appr to 60ohm.
Old 10-20-2011, 12:09 PM   #4
Hi There.
I also do the components test. The ignitor glow up for a few second. Everything seem working fine. Hmmm don't know what to do next.
Old 10-20-2011, 06:21 PM   #5
Houston204's Avatar
Rewards Points: 556
Your manual
Did you ever see the gas ignite? If so, clean the flame sensor.
Old 10-20-2011, 09:09 PM   #6
Yes I did clean the flame sensor..Test the continuity as well. When I turn on the the heat...It just goes through the process..and the led light blinking..that about it..It still work last week.
Old 10-20-2011, 09:12 PM   #7
Thanks for post the trouble diagram..
Old 10-20-2011, 09:48 PM   #8
Houston204's Avatar
Rewards Points: 556
Did the gas ever ignite?
Old 10-20-2011, 10:06 PM   #9
How do I tell if the gas ever ignite?
Old 10-21-2011, 12:49 PM   #10
Houston. Can you send me the troubleshooting flow chart? I have a hard time reading it? Do you have it in pdf file ? Thanks
Old 10-21-2011, 05:35 PM   #11
Houston204's Avatar
Rewards Points: 556
I have already posted a link to the troubleshooting guide. Left click the word manual in post #5. It is on page 10.
Old 10-22-2011, 01:05 AM   #12
Thanks you..I will follow these procedure and let you know how it goes.
Old 10-23-2011, 12:27 AM   #13
Houston204.
Thanks for helping out..I furnace is working now. all I have to do is reset the DSS switch.
Old 10-23-2011, 01:54 PM   #14
Houston204's Avatar
Rewards Points: 556
http://www.docs.hvacpartners.com/idc...it/58t-6sm.pdf
Any restrictions in the vent pipe?
Did you have to reset this spill switch more than once?
Someone hijacked the manual in post 5.
How to check secondary heat exchanger on Carrier SXC? Vaandjay HVAC 3 12-19-2010 11:27 AM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 12:52 PM
Product Advice - Trane or Carrier 99Problems HVAC 5 05-28-2009 06:23 PM
Carrier Infinity does not work with Control4 Thermostat o1o1o1o1 HVAC 1 02-27-2009 08:30 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-16-2008 11:25 PM
