Old 11-23-2008, 12:12 PM   #1
Carrier 8000 TS - code 24 ?
I have a carrier 8000 TS - Installed may 2003
1. furnace won't turn on
2. code 24 ( 2 short and 4 long light flashes)
3. code 24 says : secoundary voltage fuse is open - check for - short circuit in secoundary voltage wiring (24 VAC) wiring
what are my steps to fix this?
Thx
PS: My furnace was working till my hot water tank broke and water was around my furnace . I cleaned it up and used a hair dryer to dry the floor. I thought I was careful to ensure it was not close to the furance. Now the water tank is fixed by furnace won't turn on.
jumpball is offline   Reply With Quote
Old 11-23-2008, 12:56 PM   #2
HvacWiz's Avatar
The fuse is located on your circuit board(in the front), It is a 3 amp automotive type fuse. If you dont have a 3amp you can use a 5 amp fuse but not any higher. Try replacing the fuse and if it blows again then you know you have a 24v short somewhere.
HvacWiz is offline   Reply With Quote
Old 11-23-2008, 01:46 PM   #3
Perfect! I replaced the fuse and the furnace is up and running. Thank you for saving me a service call that I have cancelled for monday!
Old 05-03-2011, 09:21 AM   #4
mmm
I had the same problem this morning and woke up to a cold house. After reading your posts I checked the circuit board for the fuse and it was not fully plugged into the board. The furnace was up and running five minutes later. Many thanks!
mmm is offline   Reply With Quote
Old 06-05-2011, 04:48 AM   #5
Thank you very much! I shorted the unit out when the maintenance man left a wire unplugged and it sparked. I found the 3 amp fuse and replaced, voila! Thanks a million!!
dammitus is offline   Reply With Quote
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 11:36 PM
Carrier Furnace LED Code 34 and 14 sherjack HVAC 20 11-01-2009 09:45 AM
Weathermaker 9000 Carrier Code 31 problems HELP!! Its cold dynekcl HVAC 6 11-09-2008 04:15 PM
Carrier 58SXB code 14 problem harkerr HVAC 2 03-25-2008 10:31 PM
Carrier Infinity Control VS Honeywell VisionPRO 8000 Theromostat super_man4471 HVAC 2 04-26-2007 03:27 PM
