Carrier 58SXA Main Burner Problem... - HVAC - DIY Chatroom Home Improvement Forum
Old 10-19-2009, 12:10 PM   #1
Rewards Points: 32
Question
Carrier 58SXA main burner problem...
Hello,
I am having a problem with a 19-year old (circa 1990) Carrier Weathermaker furnace. It is a 58SXA, which, IIRC, was their highest effiency sealed combustion furnace at that time.
It has worked almost without any issues for 19-years. It now has a slight problem that will probably get worse.
Based on my observations when looking through the observation portal, during the heating cycle, everything seems to work properly until the
three main burners ignite. The three main burners light, but will only burn for about for about 5-10 seconds before I can hear the gas valve close and the burners go out. However, within seconds, the three burners will relight and burn again for only a short period of time. As this pattern is repeated, the burn time increases.
Often, the blower motor will start and continue to run while the burners are repeatedly lit and extinguished. Usually, after many cycles, the burners will stay lit. However, in some cases, the "off and on" of the burners will continue past the point where the Tstat calls for heat and the heating cycle ends. In other words, my house is being heated, but it is still worrisome that the furnace will not be capable of delivering the necessary BTUs on really cold days.
I am thinking that there is a main burner flame sensor that may be bad. However, I can only see one group of wires and they appear to only be connected to pilot assembly. Is there a sensor that is part of the pilot assembly that senses the pilot flame and the main burner flame separately or is there a separate main burner flame sensor?
Please let me know if you have any ideas. Thanks.
bfordmn is offline   Reply With Quote
Old 10-19-2009, 06:03 PM   #2
I have seen this many times on the sx furnace. That 3 wire assembly is acting up and needs to be replaced. I also recommend getting the secondary heat exchanger inspected for delamination.
Haven't see many that weren't bad. The secondary has a lifetime warranty and you will likely need a Carrier dealer to take care of this.
SKIP4661 is offline   Reply With Quote
Old 10-20-2009, 01:48 PM   #3
Rewards Points: 32
Thanks...
Does this furnace have a separate main burner flame sensor? If not, does it somehow use the pilot flame sensor to determine if the main burners light? Thanks.
Old 11-12-2011, 09:09 AM   #4
Intermittent burn problem
I am having the same problem with this same furnace. What is this 3-wire assembly that was offered as the solution, and where do I find it? Did it fix your problem?
regnistep is offline   Reply With Quote
Old 11-12-2011, 09:11 AM   #5
What is the 3-wire assembly?
What is the 3-wire assembly you are talking about to solve this intermittent burn problem on the 58SXA? Where is it located?
Old 11-12-2011, 09:14 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 382
It sits in front of and slightly below one of the burners. Follow the 1/4 aluminum pilot line from the gas valve to it. DO NOT buy any generic non OEM units as they are made offshore and with NO tolerances and are mostly junk. we had a poster here earlier with lots of problems with them. you want one in a genuine Carrier bag or box.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Main water shutoff problem GoodoleBob Plumbing 18 06-16-2011 10:33 PM
carrier 58SX ignition problem typhoon55 HVAC 5 06-08-2005 09:18 PM
