Carrier 58SX - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 12:05 PM   #1
Rewards Points: 18
Carrier 58SX
My furnace turns on ingnites works. The outside intake air PVC is getting really hot at the furnace connection and the exhaust PVC is cold. I have flame, If you feel the top of the furnace vent its like warm. The blower is on and drafting??? doesnt make sense.cool air is coming out of the vents
jrf0022 is offline   Reply With Quote
Old 01-02-2010, 12:27 PM   #2
An old Tradesmen
Rewards Points: 7,278
Is it an LP system.
Are the PVC pipes clear of snow and ice outside.
Post pic of the PVC pipes at the furnace. And tell which one you are calling the intake and exhaust.
Old 01-02-2010, 12:43 PM   #3
Rewards Points: 18
carrier
Checked the pipes outside and they seem clear. There is a small tap off the PVC prior to entering the furnace and when i unscrewed the plug leaves came out. Maybe ive got a nest or partial blockage???
Old 01-02-2010, 12:47 PM   #4
An old Tradesmen
Very possible.
Old 01-02-2010, 03:40 PM   #5
Rewards Points: 18
58sx
no clogs in either PVC pipe. there seems to be about half the suction and half the draft pressure pressure vs my other 58SX when feeling the pipes outside.
Old 01-02-2010, 04:57 PM   #6
An old Tradesmen
Ok, so you took the pipe out of that rubber boot, and checked it for obstructions.
Is this a LP system.
Could have a dirty/restricting secondary heat exchanger.
Old 01-02-2010, 05:19 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
Probably a cracked heat exchanger/overfired/plugged heat exchanger and getting flame rollout in the burner box. If the intake pipe is hot there then the burner box is overheating. Had the same thing with a cracked Keeprite. Get a Pro to check it as that can be VERY unsafe!!
Old 01-02-2010, 05:25 PM   #8
Sounds like the secondary heat exchanger is plugged. To see if it is really hooped, pull out the blower and inspect the secondary heat exchanger. If you see brown gunk all over it, or water running down the back of the furnace, it's toast. Replacement is covered under warranty.
hvac benny is offline   Reply With Quote
Old 01-02-2010, 05:43 PM   #9
Hvac Pro
yuri's Avatar
Not the labor $$ to do it.
Old 01-02-2010, 05:48 PM   #10
An old Tradesmen
Nope. Thats the bite about HX warranties.
But if your service tech is on the ball.
He'll talk you out of replacing the heat exchanger. And into taking the credit on the heat exchanger. And having a new tax credit qualifying furnace installed instead.
Old 01-02-2010, 05:49 PM   #11
Carrier pays 4 hours labor to do this under warranty.
Old 01-02-2010, 05:53 PM   #12
An old Tradesmen
Thats if they have the extended labor warranty, isn't it?
Old 01-02-2010, 06:02 PM   #13
As far as I know, the lifetime warranty on secondary heat exchangers includes 4 hours labor. Although, Ill have to see if this is only for the ones affected by the class action suit, or if it for all of them. Either way, I'd act fast because it appears that Carrier is catching on that many failures are due to improper commissioning, or rather lack of commissioning.
Old 01-02-2010, 07:45 PM   #14
Best have both of them SX furnaces checked. Them secondaries are a definite problem. Also been problems with the MXA furnaces as well.
SKIP4661 is offline   Reply With Quote
Old 01-05-2010, 07:03 PM   #15
Rewards Points: 18
Thumbs up
SX58 Heat exchanger
Thanks to all the advice . The heat exchanger had corroded and plugged up the system. Thats the bad part...The good part... Carrier covered the exchanger and labor. I only had to pay shipping. All together 100 Bucks! I would not have known to ask this if not for the you guys ...Thanks!
Carrier Weathermaker 58SX Gas Tech HVAC 7 01-28-2017 12:46 AM
Carrier 58SX Main Blower Turns On Without Command otismyman HVAC 19 09-25-2009 07:06 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-16-2008 11:25 PM
carrier 58SX ignition problem typhoon55 HVAC 5 06-08-2005 09:18 PM
