Carrier 58STA070 Error 12 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 11:09 PM   #1
Exclamation
Need some help. Here is the history that I've been working on.
Had service tech inspect. Said parts below needed to be replaced.
- Replaced ignitor element
- Replaced gas control valve
This didn't fix the problem.
Had service tech inspect. Said to replace control board. I replaced the board and it worked great for a couple of hours.
Got home from church tonight and the heat was off. Went into the attic and the LED light was continuous. SO, I turned it on and the furnace started up. About 15 seconds later a very loud crackling sound started from the furnace. I thought it was the blower but it runs fine after I power off. I got the error 12 code only once. The crackle continues each time but the LED shows continuous.
If anyone has had this happen please let me know what I need to do next...
MM227 is offline   Reply With Quote
Old 12-08-2011, 02:55 AM   #2
yes! 1 st i replaced my technician......then i replaced the main control board......and its worked great ever sense
harleyrider is offline   Reply With Quote
Old 12-08-2011, 09:32 AM   #3
The crackle should is similar to a partially plugged in lamp/appliance. An electrical crackle.
Would appreciate some real help and suggestions. I have 3 small kids and it gets pretty chilly at night.
Old 12-08-2011, 10:36 AM   #4
If you are hearing an electrical arcing sound you need to check your line voltage wiring. An improperly grounded furnace will give you fits and be aggravating to diagnose if you're just swapping parts hoping for the best.
brandonmcginnis is offline   Reply With Quote
Old 12-08-2011, 11:08 AM   #5
Thanks for the tip. A bit nervous working with electrical...think I'll call a tech for this one!
Old 12-08-2011, 11:43 AM   #6
If you aren't comfortable working with electricity that is absolutely your best option.
Tags
58sta070 , carrier furnace , error code 12
How to check secondary heat exchanger on Carrier SXC? Vaandjay HVAC 3 12-19-2010 12:27 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Carrier Infinity thermostats integrate with control4 2.0 Proteco HVAC 0 07-09-2010 06:33 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-17-2008 12:25 AM
