Carrier 58sta/stx Has No Power - HVAC - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 10:01 AM   #1
Unhappy
Carrier 58sta/stx has no power
For some unknown reason to me, my furnace has no power. It is a Carrier model 58sta/stx. It is controlled by a Honeywell digital thermostat, which at this point has no display functions (blank) and is why I believe there to be no power to the system.
Any suggestions?
Kherg62 is offline   Reply With Quote
Old 03-06-2011, 10:11 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
check your breakers and possibly there may be a switch by the furnace. There is also a low voltage fuse on the control board located in the blower compartment. Also some of these brand furnaces would shut off the outgoing power to the stat when a limit was tripped.
Also check for batteries in the stat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-06-2011, 01:55 PM   #3
May be a bad transformer. Are you getting 110v to the furnace? If so, are you getting 24v out the other side of the transformer?
Poppyloppy is offline   Reply With Quote
Old 03-06-2011, 07:37 PM   #4
:thum bup:: thumbup:
Trouble shot the power back from the 24v secondary side of the transformer. Pretty scary what I found. The wiring in at the power into the furnace had gotten so hot it burned up. The hot line in wire nut was all melted. Nothing shorted out...no breakers ever blew, I was pretty suprised at this! So all it took was cutting back the wirring and renutting the lines together. Alls good and up and running.
Thanks for everyones help!
Old 03-06-2011, 11:06 PM   #5
JJboy's Avatar
I do not think you found the cause of the problem. I'd add a fuse if a random short It will open the fuse and it won't damage anything.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 08:45 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 08:26 PM
Problem with Carrier Weathermaker 9200 Chipley HVAC 12 12-16-2008 01:44 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
