Carrier 58st/error Code 33/to13 - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 08:44 PM   #16
Rewards Points: 14
thanx for the help
freezeradio is offline   Reply With Quote
Old 09-28-2010, 04:28 AM   #17
Rewards Points: 14
Originally Posted by freezeradio View Post
I hope that dosent meen that I have to get a new board?
really bummed out that I have to spend big money on an old fau.I wonder if I should get a new fau.
Old 09-29-2010, 07:29 PM   #18
Rewards Points: 14
My price on the circuit board is 268.79 That seems a little high. anyone know where i can get a better price it is a 42fz013
Old 09-29-2010, 08:24 PM   #19
HVAC / Plumbing
I don't buy my parts on line.But, I googled that # and found HK42FZ013 for 199.99. Check your part # for the letters followed by #
kenmac is offline   Reply With Quote
Old 09-29-2010, 09:04 PM   #20
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
Post the complete model # of the furnace. Code 33 followed by 13 means a limit switch is open. Check the one over the burners and the spill switch which is a resetable switch attached to the side of the exhaust fan box. Check the furnace fan itself as some have secondary limit switches on there. All these switches are in series. Post the model # and a pic of the wiring diagram so we can trace it for you. May also have a bad wiring harness or connection. O-3 volts to the ventor fan is normal if a limit is open. Those have to close first.
Old 09-29-2010, 09:47 PM   #21
HVAC / Plumbing
does your unit have this switch ? Hope it's ok to post this . I worked on a carrier of this mod. last year where this limit was tripped but, I can't remember if the vent motor was constant on or not. I know the blower motor was
http://www.youtube.com/watch?v=PQ8ZD...eature=related
Old 09-30-2010, 11:24 AM   #22
Rewards Points: 14
It was the Board.268 and change to fix it. thanx for your help guys. This sight rocks.
Old 09-30-2010, 12:36 PM   #23
HVAC / Plumbing
glad to hear you got it going
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Carrier Infinity thermostats integrate with control4 2.0 Proteco HVAC 0 07-09-2010 05:33 PM
Product Advice - Trane or Carrier 99Problems HVAC 5 05-28-2009 06:23 PM
Honeywell TrueSteam with Carrier Infinity Control Llama HVAC 1 02-19-2009 04:20 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-16-2008 11:25 PM
