Carrier 58st/error Code 33/to13 - HVAC - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 08:25 PM   #1
Rewards Points: 14
Carrier 58st/error code 33/to13
I have a 6 year old fau with an error code that sais limit or vent blockage or obstruction.I checked it out and all I can figure is that the non resetable switch above the burrners is bad
I omed it out to 0 . still think it has to be the problem....Can anyone shed some light on this subject. before I nickel and dime myself to .....
freezeradio is offline   Reply With Quote
Old 09-27-2010, 08:28 PM   #2
HVAC / Plumbing
If you took the wires off that limit & it read 0. That means it's good. Check vent for obstructions..You can jump out limits ( if you know how ) until you find the 1 that is open.. Don't leave it jumped out . Find out why it opened.. Could be bad heat exchanger or not venting properly both of which can be deadly
kenmac is offline   Reply With Quote
Old 09-27-2010, 08:34 PM   #3
Rewards Points: 14
yep I checked the vent . I really think it is something else but also think if the limit got hot ,Would it not work?
Old 09-27-2010, 08:37 PM   #4
HVAC / Plumbing
If the limit got hot & opened . It would shut down the furnace. It could be the type that resets after cool down
Old 09-27-2010, 08:40 PM   #5
HvacWiz's Avatar
Rewards Points: 252
check the small rubber hose going from the back of the pressure switch to the collector box. that connection on the box is probaly plugged up, not allowing the pressure switch to pull in.
HvacWiz is offline   Reply With Quote
Old 09-27-2010, 08:43 PM   #6
Rewards Points: 14
yes i did that also not plugged up. I turn on fau and blower comes on nothing else .
Old 09-27-2010, 08:45 PM   #7
HVAC / Plumbing
does the vent motor come on ?
Old 09-27-2010, 08:50 PM   #8
Rewards Points: 14
no vent motor
Old 09-27-2010, 08:54 PM   #9
HVAC / Plumbing
Originally Posted by freezeradio View Post
no vent motor
So, It doesn't have a vent motor ? or it isn't comming on
Old 09-27-2010, 08:54 PM   #10
Rewards Points: 14
sorry the vent motor is not on.
Old 09-27-2010, 08:58 PM   #11
HVAC / Plumbing
on a call for heat the vent motor should start if it's good & has power to it.. Check vent motor & power
Old 09-27-2010, 09:00 PM   #12
Rewards Points: 14
it olny has 3 volts going to the vent motor.
Old 09-27-2010, 09:03 PM   #13
HVAC / Plumbing
. Check the terminals on the board where the vent motor plugs in when calling for heat
Old 09-27-2010, 09:21 PM   #14
Rewards Points: 14
No power at the teminals on the board
Old 09-27-2010, 09:22 PM   #15
Rewards Points: 14
Hate buying parts
I hope that dosent meen that I have to get a new board?
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Carrier Infinity thermostats integrate with control4 2.0 Proteco HVAC 0 07-09-2010 06:33 PM
Product Advice - Trane or Carrier 99Problems HVAC 5 05-28-2009 07:23 PM
Honeywell TrueSteam with Carrier Infinity Control Llama HVAC 1 02-19-2009 05:20 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-17-2008 12:25 AM
