Carrier 58RAV075 CFM? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 06:09 PM   #1
Hi,
I have an older Carrier 58RAV furnace (92k BTU) and I was under the house to inspect the ductwork since cold air was billowing into the house and it's all messed up. It looks like it was done a previous home owner. I'd like to replace it since it's all coming apart and I am heating the neighborhood up. I looked online though and can't find out how many CFM this furnace outputs. Does anyone know?
Thanks!
Sean
snlfuller is offline   Reply With Quote
Old 01-11-2011, 08:56 AM   #2
Rewards Points: 494
Found manual here:
http://www.xpedio.carrier.com/idc/gr.../58p,r-7sm.pdf
For air handlers, use most of above url but substitute these for last pdf part until you find the 075 match:
58rav-1pd.pdf
58rav-2pd.pdf ... up to 7pd.pdf
diyorpay is offline   Reply With Quote
How to check secondary heat exchanger on Carrier SXC? Vaandjay HVAC 3 12-19-2010 11:27 AM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 12:52 PM
Carrier Infinity does not work with Control4 Thermostat o1o1o1o1 HVAC 1 02-27-2009 08:30 PM
Carrier 58RAV075 series 100 vwnutman HVAC 4 01-22-2009 08:07 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-16-2008 11:25 PM
