Carrier 58RAV Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2008, 07:11 PM   #1
I recently noticed that my upstairs unit was not heating. I had a schedule service call schedule when the repairman came out he told me my transformer was bad. so he replaced it, but still nothing. He then told me my control board was shot (HK42FZ009). He did not have a board told me it would need to be ordered at a cost of $600 (plus $150 for the Transformer).
2 questions.
1. I have searched on line for the board and it appears that a new board has been made to replace this one that has extra wires to connect. Is this the correct replacement and can a very good handyman(me) do this.
2. The repairman took the transformer, so I have no idea what transformer I need or how it hooks up. any help here?
Thanks,
Mike
prattm is offline   Reply With Quote
Old 12-13-2008, 07:31 PM   #2
There is a retrofit board replacement kit for this furnace. The transformer is a 110 volt primary/24 volt secondary/40 va transformer. There should be fairly detailed instructions with the new board. Is the 3 amp fuse on the circuit board blown. You may not have a bad transformer. Have seen lots of these boards go bad though. Price is kind of high too.
SKIP4661 is offline   Reply With Quote
Old 12-13-2008, 08:49 PM   #3
Any idea on a part# for transformer?
Is the retrofit board easy to install?
Old 12-13-2008, 09:00 PM   #4
Does anyone know of a reliable and cheap place to get these parts?
Old 12-14-2008, 04:58 AM   #5
HvacWiz's Avatar
Rewards Points: 252
Charging you 150$ for a 20$ transformer...WOW. Now that what I call a mark up.
HvacWiz is offline   Reply With Quote
Old 12-14-2008, 07:56 AM   #6
An old Tradesmen
Rewards Points: 6,586
If its a flat rate comany. Thats the installed price.
Not out of line.
Tags
carrier , control board , furnace , hk42fz009
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 11:36 PM
Carrier 58MCA Furnace No Heat (Error 33) zerafah49 HVAC 1 12-10-2008 08:32 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 01:00 AM
