Old 12-15-2008, 12:54 AM   #1
Carrier 58RAV Continuous On
After the re-install of a igniter, my furnace does not seem to respond to settings at thermo. At the furnace i get LED constant on (24V code) and furnace stays on blowing air and heat. The only way to turn it off is to hit the breaker etc. I've replace batteries in thermo etc. but heat keeps blasting.
yanosan is offline   Reply With Quote
Old 12-15-2008, 06:30 AM   #2
An old Tradesmen
Go seperate the wires you bumped.
Probably a red and white wire.
Old 12-15-2008, 01:30 PM   #3
Thanks,
It turns out that the HvAC guy who came to diagnose the problem (igniter was bad) left a "jumper" connecting the red and white terminals (just like you said). I removed the wire and things roll along nicely.
Old 12-15-2008, 04:10 PM   #4
An old Tradesmen
I like simple ones.
Carrier 58RAV Furnace prattm HVAC 5 12-14-2008 07:56 AM
Carrier 58RAV Continuous On yanosan HVAC 2 12-09-2008 01:17 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-17-2008 12:25 AM
Carrier 58RAV LED code 14 issues kcb68 HVAC 2 03-29-2008 03:12 PM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 01:00 AM
