Carrier 58pav070-12 Error Code 34 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2010, 06:14 PM   #1
Carrier 58pav070-12 error code 34
I get the code only every so often and under several circumstances. It will come on if the furnace runs too long, such as if I come home from work and increase thermostat more than 3 or 4 degrees. It will also come on if the furnace is running for a little while and I increase the temp, even if its just a degree or two.
Inducer motor starts, igniter comes on, flame starts and stays on for a couple seconds, then I get the error code 34. I have cleaned the flame sensor often with steel wool.
Could I have an issue with the gas valve or the circuit board. Because it will run smoothly for weeks as long as nothing is done as I stated above, I have to think the board might be bad.
Any suggestions would be appreciated and thanks in advance.
Patka is offline   Reply With Quote
Old 12-27-2010, 07:26 PM   #2
What does the chart on the furnace say a code 34 is?
Old 12-27-2010, 08:23 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,230
Could be a bad board or sticking gas valve or a number of other problems. Tech would have to be there to see it. I sometimes cycle start/stop them 20-30X in a row to try and catch an intermittent problem ( those are the WORST).
Save this pic for future use Marty, right click and Save as.
Old 12-28-2010, 12:17 PM   #4
Thanks for the response Yuri. Knowing that it is only an intermittent problem leads me to believe it's the board.
Has anyone seen this issue before?
Old 12-28-2010, 01:02 PM   #5
Hvac Pro
yuri's Avatar
Read all about it:Bryant 383KAV048111 starts up intermittently
Cousin of your furnace, common for those boards to fail/wear out or develop problems. Happens to all brands and boards eventually.
How to check secondary heat exchanger on Carrier SXC? Vaandjay HVAC 3 12-19-2010 11:27 AM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 12:52 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
Product Advice - Trane or Carrier 99Problems HVAC 5 05-28-2009 06:23 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-16-2008 11:25 PM
