Carrier 58PAV Not Cycling On And Off - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 08:44 AM   #1
Carrier 58PAV not cycling on and off
Hello all, I purchased a home a few months ago with a Carrier 58PAV unit. The AC worked fine but I'm having a problem with the heating, it would not come on so I changed out the thermostat but quickly realized that was not the problem. If I turn on the thermostat and turn off the main switch on the heating unit and then turn it on the unit will run properly until it cycles again the unit will light and the burners will ignite but within a few sec. shut off.
Any help would be greatly appreciated
Bill
billytjr is offline   Reply With Quote
Old 11-18-2009, 02:34 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
Clean the flame sensor with fine emory paper. Sits in front of the left burner and looks like this:
Old 11-18-2009, 02:56 PM   #3
Thanks for your reply Yuri I founds the panel with the codes listed and it directed me to the Flame Sensor, I took it off and cleaned it and all is well. Thank you.
