Carrier 58PAV Inducer Motor Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 10:32 PM   #1
Hey all.
I have a Carrier 58 PAV Furnace, and for the past several days it's been making an increasingly disturbing noise, a high pitched humming/whistling noise, that is coming from the induction motor assembly. When the motor assembly turns off, it sounds like a jet engine powering down. All the noise goes away when it stops spinning. Any idea what this means or what's causing the problem? Does it need to be replaced? The furnace seems to be functioning properly despite the noise. Any help or insight is greatly appreciated.
mad116 is offline   Reply With Quote
Old 01-13-2010, 10:37 PM   #2
pull the lowest drain tube the black rubber ones on the inducer enclosure and see if water comes out (more than a couple drops) if so drain trap may be clogged and preventing proper drainage makeing the blower wheel become a paddlewheel
kennzz05 is offline   Reply With Quote
Old 01-13-2010, 10:43 PM   #3
thanks, will try
Old 01-15-2010, 01:23 PM   #4
Hey there, I came across this topic because I have the same Carrier 58PAV (12 yrs old) and I have a new growling/rattling noise coming from somewhere in the inducer motor assembly. I'm about to head to the parts store but I'm unsure if I need the wheel, the motor, or both. I already took the assembly out and the fiberglass gasket is worn-out and won't be able to be salvaged. I saw the reply to this post and don't have any rubber black hosings for draining. Is that a humidifier/dehumidifier item that might be optional?
Question for the experts: I took the wheel off the inducer and noticed that there's a little play in the hub and the wheel itself. Is that normal or should the hub be held immobile to the wheel?
Thanks!
DIYCHICAGO is offline   Reply With Quote
Old 01-15-2010, 06:52 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
A Pav is a mid efficiency furnace with no drain hoses. You need to replace both the motor and wheel as it gets off balance. Be VERY careful how you handle those wheels as they bend VERY easy and get off balance and will create vibration and future noise.
Old 11-07-2011, 02:37 AM   #6
Hi Yuri,
Can you please tell where can I find parts for Carrier Furnace 58PAV in Calgary, Canada, particularly the inducer motor and gaskets rather than replacing the whole assembly.
Masroq is offline   Reply With Quote
Tags
58pav , carrier , inducer motor , noise
Inducer motor; ID on Part: Carrier Part # HC21ZE123A - Cross reference help mtom01 HVAC 10 02-20-2011 07:43 PM
Carrier Model 58MVP inducer motor deanray HVAC 11 11-19-2010 05:33 PM
Carrier 58PAV not cycling on and off billytjr HVAC 2 11-18-2009 02:56 PM
Carrier Weather Maker inducer voltages used2beatech HVAC 16 10-16-2009 03:43 AM
Carrier Draft Inducer Problem? ChiTown HVAC 5 12-24-2008 08:16 AM
