Carrier 58PAV Error Code 12 And 33 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 12:42 AM   #1
Carrier 58PAV error code 12 and 33
I have an old Carrier 58PAV furnace with blower fan not working. One start it shows code 12 after a while the vent fan comes on followed by burner running for about 3 minutes and kills the burner and shortly after that the vent fan stops as well. LED shows code 33 at this point. The blower fan never starts.
Any help is appreciated.
HashamSyed is offline   Reply With Quote
Old 10-22-2010, 05:44 AM   #2
An old Tradesmen
Rewards Points: 6,148
Back of the panel should have the error code legend.
The 12 just means that power was turned on to the furnace while the thermostat is calling for heat.
Old 10-22-2010, 09:06 AM   #3
I tried turning the thermostat OFF and then back on again but it goes back to the same 33. If the power to the furnace is turned off and back on it seems to reset the code and it takes an attempt to start back up again but fails. There has been no change to the setup. It has been running fine for the past year and a half, that's how long I have had the house for. How do I get the blower fan to work?
Old 10-22-2010, 12:27 PM   #4
HVAC / Plumbing
Try turning the fan to on at t.stat if you have that function & see if blower runs. Sounds like blower won't start & it shuts down on high limit.
kenmac is offline   Reply With Quote
Old 10-22-2010, 12:36 PM   #5
Yes I tried that. Turning fan to ON does not start the blower fan.
Old 10-22-2010, 01:34 PM   #6
HVAC / Plumbing
Possible bad blower , board, cap., relay, etc, check & see if you have voltage to the blower motor. Probably doesn't work on a/c either
Old 10-22-2010, 04:49 PM   #7
An old Tradesmen
Look on the panel and see what code 33 means.
You probably have an open limit, or roll out switch.
Old 10-22-2010, 05:56 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 1,174
For future reference, feel free to save them guys:
Right click and save as jpegs.
Carrier 58PAV error code 12 and 33-carrier-codes.jpg   Carrier 58PAV error code 12 and 33-carrier-codes-2.jpg
Tags
58pav , blower fan , carrier , error 12 , error 33
Carrier 58PAV KenP HVAC 15 11-21-2016 10:55 PM
Carrier 58PAV Error code 14 Hermmona HVAC 9 01-05-2012 11:42 AM
Carrier 58PAV Inducer Motor Noise mad116 HVAC 5 11-07-2011 02:37 AM
Carrier 58PAV not cycling on and off billytjr HVAC 2 11-18-2009 02:56 PM
Carrier Furnace Model 58PAV error code 34 ColdInNJ HVAC 2 02-04-2009 09:38 PM
