Carrier 58PAV - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2012, 10:09 AM   #1
Carrier 58PAV
My furnace starting acting up lately but I am not sure if its the furnace or the thermostat.
If I power off the furnace, when I power it back up, it seems like it is working. It ignites but them the flames go out after 10 seconds or so and then the blower kicks in. It will do this a few times and then stop.
I dont know if there is an issue with the furnace and its tripping (or not) some sensor and shuts itself off or if its getting a signal from the termostat to not run. The temp it says on the thermostat is well below what I have it set to so it should be kicking on.
I understand there is an LED somewhere that will show a code, but I am not sure where that is.
Thanks,
--Mike
MelThorpe is offline   Reply With Quote
Old 11-06-2012, 11:07 AM   #2
how
Rewards Points: 1,104
The led will usually be visable through a viewing port in the furnace door. It's located on the electronic board. Opening the furnace door will usually kill the power to the furnace and the led so check for the diagnostic light beforehand.
Some furnaces require taping in the furnace door switch to be able gain access to the led without shutting it off. There will be a legend to describe the fault on the inside of the furnace.
A dirty flame sensor is one of the more common causes to check & correct from what you are describing. (if you can't find the led)
how is offline   Reply With Quote
Old 11-06-2012, 11:14 AM   #3
I will have to check the LED when I get home.
A bit more detail on what it's doing.
~A fan will kick on and run for a few minutes
~I hear a click and then the flame lights
~The flame may stay lit for a bit
~Then a fan starts running
~Everything stops for a short time period and then it starts over again.
I'm thinking you are right. I am going to give the flame sensor a good cleaning.
Old 11-06-2012, 05:29 PM   #4
Rewards Points: 582
yep start by cleaning flame sensor..ben sr
Carrier 58PAV Error code 14 Hermmona HVAC 9 01-05-2012 10:42 AM
Carrier 58pav flame pattern question italie HVAC 4 11-17-2011 12:45 PM
Carrier 58PAV error code 12 and 33 HashamSyed HVAC 7 10-22-2010 04:56 PM
Carrier 58PAV not cycling on and off billytjr HVAC 2 11-18-2009 01:56 PM
Carrier Furnace Model 58PAV error code 34 ColdInNJ HVAC 2 02-04-2009 08:38 PM
