Carrier 58MXA Series 170 Trouble With Temperature - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 01:07 PM   #1
Carrier 58MXA Series 170 trouble with temperature
Carrier Model 58MXA 100-16 Series 170 is not maintaining temperature via the heat pump. If I switch to emergency heat the propane gas kicks in. It is not cold here - about 45 degrees. I had the heat set on 70 and the temperature in the house was 66. You can hear the fan running but it is not heating properly in the heat pump mode. Any ideas?
xrayeyes2u is offline   Reply With Quote
Old 01-24-2010, 01:19 PM   #2
Could be a lot of things not making the heat pump run. Need to check the breaker first. Then set the thermostat back to heat and 1 degree below the room temp. Then go outside and see if the compressor and condensor fan motor are running.
Old 01-24-2010, 02:00 PM   #3
Thanks for the reply! Yes, the compressor & condensing fan are running.
Old 01-24-2010, 02:37 PM   #4
An old Tradesmen
Rewards Points: 8,242
Check your air filter.
Old 01-24-2010, 02:43 PM   #5
air filter fine.
Old 01-24-2010, 02:46 PM   #6
An old Tradesmen
If you just checked or replaced it yesterday.
then you need to check to see if the heat pump is running the whole time the thermostat is calling for heat. But net reaching set temp(guessing that it could reach set temp at same conditions earlier, like last year).
If it is. Then you need the unit checked. Could be a charge problem.
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Carrier 58MVP Series 140--Blower Specs--Custom Config. mogmen HVAC 12 11-01-2009 08:29 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
