Old 12-09-2008, 01:49 PM   #1
Carrier 58MCA Furnace – No Heat (Error 33)
Can anyone help? My carrier 58MCAD80-12 furnace is not providing any heat. I’d had a problem with my humidifier, and had just repaired it. I had been running the furnace at 80 deg for a few minutes to make sure the humidifier was working properly. When I wanted to adjust the temp back to 70 deg, I found that the LED display on the thermostat was blank – just as if the power switch of the furnace was off (but this was while the furnace was still running) I also noticed then that the furnace was blowing cold air.
What could I have done to cause this problem? Or is it possible that it’s a totally unrelated problem that just happened to occur while I was working on it?
Thinking that perhaps something may have gone wrong with the thermostat, I replaced my existing thermostat. The problem persisted – still no heat. The flame does not light up in the burner.
I then did what I should have done first, and went through the troubleshooting steps in the manual. I am getting a code 34 LED code (Limit Circuit Fault) which continues for a while, and then changes to a 13 LED code (Limit circuit Lockout). Under LED code 13, the manual says the “Control will reset after three hours”. Nothing changed even after three hours.
As you can probably tell, I’m not very savvy with HVAC equipment, but wouldn’t want to call in a repairman unless I absolutely had to. Can anyone help?
zerafah49 is offline   Reply With Quote
Old 12-10-2008, 08:32 PM   #2
An old Tradesmen
The limit is stuck open from running it at 80 degrees.
More On This Topic
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Hello! This is Ross on behalf of expertvillage.com. Resistors resist current flow. In this circuit here is LED, was being protected by these two resistors. They are resisting the amount of current flowing through. Otherwise the LED would have burnt out... Read More »
When you're dealing with mold, it's very important to make sure you have a fine balance of having moisture in the air of your house and having too much moisture in the air of your house. Because with too much moisture, mold spores are actually airborne... Read More »
Eczema & Humidifiers
Eczema & Humidifiers by Expert Village
It's very important to maintain the right amount of humidity in your home. People that experience eczema have to make sure that three's enough moisture in the air that their skin isn't dry or cracking. You know how in the winter time especially here in... Read More »
carrier furnace...no heat blower won't stop kevinp HVAC 16 10-24-2009 03:21 PM
Carrier Furnace help code 31 fauxjaux HVAC 2 04-10-2008 11:17 PM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 01:00 AM
BRRRR! NO HEAT! PLEASE HELP! Old Carrier Furnace! joeraccio HVAC 3 10-12-2007 10:47 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
