Old 07-24-2012, 07:33 AM   #1
Carrier 58HDV Furnace
I had a new 58HDV furnace installed; I had a single stage Thermostat with my previous furnace and the installer stated I would not benefit from installing a two stage Thermostat. I am looking for comments either to confirm this statement or provide me reasons for replacing my existing Thermostat to a two stage.
66vette is offline   Reply With Quote
Old 07-24-2012, 09:43 AM   #2
Assuming it's this furnace:
http://www.residential.carrier.com/p...rmance95.shtml
It's a single stage furnace, so there's no benefit to installing a multistage tstat.
This one:
http://www.residential.carrier.com/p...mance95t.shtml
Is a multistage gas furnace.
scottmcd9999 is offline   Reply With Quote
Old 07-24-2012, 10:50 AM   #3
It is the 58 hdv furnace per the specifications attached it is a two stage, variable speed furnace.
http://www.docs.hvacpartners.com/idc...58hdv-01pd.pdf
Old 07-24-2012, 11:09 AM   #4
That's odd ... there seem to be some discrepancies in the manuals I found, and some of them seem to indicate that the 58HDV line is not multi-stage heat, while others do.
Do you have the exact model number for the furnace? Also, does the nameplate on the furnace list both high and low stage heat ratings?
If you DO have the furnace indicated in your link, then that IS a multistage furnace, and you would perhaps benefit from a multistage thermostat - although some furnaces control this outside of the thermostat (i.e. they ramp up from low to high heat based on a time schedule).
What are the carrier furnace codes? porang HVAC 1 01-24-2011 08:45 PM
Carrier Furnace bmak3 HVAC 1 01-13-2011 07:43 PM
Carrier furnace problems BigK75 HVAC 1 07-30-2009 06:16 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 10:48 AM
