Carrier 58GS Blower Stoped Working - HVAC - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 03:47 PM   #1
Carrier 58GS blower stoped working
Hello, I have a 1990 Carrier Model 58GP,GS
Carrier
model 58GS100-3
series 301
Blower 109
1/2 hp
I could smell an electrical burn and the motor has stopped blowing.
I cant figure out how to get the lower panel off. The upper on with the vents lifted out easy.
Anyone know a model # of the blower and how to open the panel?
Thanks for taking time to read this.
Trops357 is offline   Reply With Quote
Old 04-18-2013, 05:08 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
post a picture of the panel, the entire front of the unit. we'll tell you how to remove it once we can see it like you see it.
it's going to be the blower motor or the capacitor, why the blower is not running.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-18-2013, 08:04 PM   #3
pics
Thanks for such a prompt reply.
Here are some pics.
http://i381.photobucket.com/albums/o...Untitled-2.gif
http://i381.photobucket.com/albums/o...Untitled-3.gif
http://i381.photobucket.com/albums/o...s/IMAG0021.jpg
http://i381.photobucket.com/albums/o...s/IMAG0022.jpg
http://i381.photobucket.com/albums/o...s/IMAG0023.jpg
http://i381.photobucket.com/albums/o...s/IMAG0024.jpg
http://i381.photobucket.com/albums/o...IMAG0025-1.jpg
http://i381.photobucket.com/albums/o...s/IMAG0026.jpg
Old 04-18-2013, 08:37 PM   #4
Rewards Points: 446
The bottom panel just slides up. It hooks over the shelf on the inside top. If it hasn't been open in a few years you might need to use something slid into the bottom slit and pry up.
old_squid is offline   Reply With Quote
Old 04-18-2013, 08:48 PM   #5
Roofmaster
Rewards Points: 2,210
Yeah, you just slide it up and out toward you. Remove the two screws that hold the board mounting bracket in then the two 5/16" HWH screws that hold the motor in and it slides right out on its rails.
Check www.pexsupply.com for a new motor
Old 04-20-2013, 09:38 AM   #6
Thank you so much for the replies and links.
It came off no problem with just a little preasure using
a screwdriver at the bottom.
Here is a pic.
I guess I need to remove the box to get the blower out.
Seems to be enuf wire to just place it out of the way
while I pull out the blower.
Breaker is OFF.
Time to get on the floor and get a little dirty!
Old 04-20-2013, 10:17 AM   #7
it's childsplay in all honesty. do you have a meter to test voltage? perhaps one that tests mfd (microfarads)?
Thanks.
Old 04-20-2013, 11:02 AM   #8
I loosened the set screw on the shaft of the motor.
I removed the 3 bolts holding the motor to housing.
Bushings are in good condition.
Then as I moved it, I heard a "slosh sound".
Yeah, it had water in it.
The water was clean.
It was only the second time this season I had used the A/C.
The 1st time some water leaked from the Left Rear corner, about
2.5 ft. It stopped running to the floor after it reached about 2.5 feet
and the A/C worked fine, and blower was still running.
The 2nd time , which was the day I first posted here, it leaked about
4 in. at the same corner. Then my wife smelled something
electrical burn. I went to basement and the motor/fan had a different
sound, sounded slower and labored. The A/C cut off, and when I tried
to restart the blower never came back on.
Any ideas on how to look for blockages that might cause water to build
up inside the furnace?
Inside of the blower is not rusted or anything like that. I do see some
rust on the back inside wall of the furnace.
Old 04-20-2013, 11:07 AM   #9
yes, I have meter. I used to repair 3 phase motors. Check for continuity,
short to the housing, bearings, etc.
They did not have capacitors or circuitry for variable speeds.
Can you give me some advice on testing the motor and/or
the capacitor.
Old 04-20-2013, 12:10 PM   #10
My meter, try not to laugh
I got 2 sets of Wiggly's too
Old 04-21-2013, 06:36 PM   #11
That meter looks like it doesn't have a setting for measuring capacitance (mfd or microfarads)
Also, it could be possible that the control circuitry (controller or relay) burned. I've witnessed a few Control Board's burn on older Carrier furnaces.
Just trying to help. For the record, I'm not a technician
ModelAFan is offline   Reply With Quote
Old 04-21-2013, 07:12 PM   #12
Thank you
Old 04-21-2013, 08:08 PM   #13
Rewards Points: 582
Originally Posted by Trops357 View Post
Thank you
you can also test a capacitor with a multimeter....set for olms hook to cap them set to dc volts meter will start to discharge through meter showing good capacitor..ben sr
Old 04-22-2013, 08:30 AM   #14
Thank you !
The Following User Says Thank You to Trops357 For This Useful Post:
ben's plumbing (04-23-2013)
Carrier 58MVP -blower continues to run realprop HVAC 15 01-24-2012 11:37 PM
Carrier 9200 Weathermaker not working markwells HVAC 1 09-27-2011 07:22 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
HELP! Carrier Weathermaker Infinity Not Working! MaxPierre HVAC 27 01-19-2009 06:30 PM
RUUD furnace not working blower runs ddeatrick99@hotmail.com HVAC 2 01-16-2008 09:55 PM
