Old 01-30-2010, 04:18 PM   #1
Question
Carrier 58gc100-2a furnace
I have a Carrier 58gc100-2a furnace and Burner keeps cycling on and off how can I troubleshoot this? I have lived in the house for two years and have not had the furnace cleaned. I can see debree in one of the chambers. Could this be causing it to cycle on and off? The burner fires for about 30 sec then shuts off for a short period then fires again.
kwheeler02 is offline   Reply With Quote
Old 01-30-2010, 04:32 PM   #2
HVAC Tech/ Browns Fan
Need to clean Flame sensor. it a small round metal rod it has a white wire going to it too
Tator1076 is offline   Reply With Quote
Old 01-30-2010, 04:32 PM   #3
it may be front of a burner
Old 01-30-2010, 04:34 PM   #4
clean it with a dollar bill or something soft no sand paper
Old 01-30-2010, 05:13 PM   #5
Thank you so much for your assistance. I do not see anything that fits that description. The closest thing is a rod or tube that is 1 to 2 inches long that leads up to the pilot light.
Old 01-30-2010, 06:21 PM   #6
Ok well the flame sensor is there with the pilot. Need to remove it and clean it. Be easy to pop it out.
Old 01-30-2010, 07:42 PM   #7
Houston204's Avatar
Is this furnace closer to a 1973 or closer to a 1983? The 3rd and 4th digit may indicate year. Older models used to have a letter and number indicate year. A thru M indicated 1970's and N thru Z was 80's. I recommend having your furnace professionally inspected.
http://www.docs.hvacpartners.com/idc...8ga,gc-2si.pdf
Houston204 is offline   Reply With Quote
Old 01-30-2010, 07:48 PM   #8
Angry
I think I just shot myself in the foot. Could not take that piece off so I cleaned it with a tooth brush and vacuumed the top of the burner tubes now the furnace will not fire at all. Any suggestions? I live in Richmond Va we just got 12 inches of snow I will not get anyone out here to help probably for a couple of days.
Old 01-30-2010, 10:13 PM   #9
Did made sure door pandel is on right? You make sure the service switch is on? You may need check the low voltage fuss
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 11:36 PM
Carrier furnace problems BigK75 HVAC 1 07-30-2009 06:16 PM
Carrier 58MCA Furnace – No Heat (Error 33) zerafah49 HVAC 1 12-10-2008 08:32 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
