Carrier 58DHB Pilot Wont Ignite - HVAC - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 01:17 PM   #1
Carrier 58DHB pilot wont ignite
I have an 18yr old Carrier model 58DHB095 NatGas/AC in my attic. Now, when the thermostat calls for heat, nothing happens. No clicking, no noise at all except at the thermostat. The fan works fine when turned on. I replaced the thermostat buy that didn't fix it.
I have a similar unit in my basement 58GS100 which clicks when igniting. They appear to have the same pilot ignition system. Would replacing this solve the problem or should I check something else before buying the parts? I may try to clean it first. Any help is appreciated.
bobrup is offline   Reply With Quote
Pilot lite on Carrier Furnace goes out nmac HVAC 8 10-08-2012 07:32 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Older Carrier Pilot Burner Problem cliffkot HVAC 23 04-29-2011 06:58 PM
pilot lit, burner won't ignite unless I blow on pilot light rl5 HVAC 7 01-06-2011 10:08 PM
10 year old Carrier mid furnace with standing pilot BryanGregoire HVAC 3 10-01-2009 07:16 PM
