Carrier 58bb125-2bc - HVAC - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 01:04 PM   #1
Rewards Points: 268
carrier 58bb125-2bc
Old Carrier gas unit. Blower runs all the time. Even with the thermostat totally disconnected. Only way to stop it is to kill power. Please help. Thanks.
JackDidley is offline   Reply With Quote
Old 09-02-2013, 01:10 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
Post pics of it with both doors off and close up of the control board. probably the fan relay on it is sticking. gently rap it a few times. if it stops then dats yur problem.
Old 09-02-2013, 01:12 PM   #3
Rewards Points: 268
Im doing this remote. Said unit is in another town. He has tapped the relay with no effect. He also says it has no control board.
Old 09-02-2013, 01:26 PM   #4
Hvac Pro
yuri's Avatar
Is he a tenant? There may be a white button or switch if it is a very old unit on the fan control for Summer fan operation. that may be pushed in or slid on. some units also had a Summer fan button on the side of the furnace but not usually Carrier. worth lookin 4 anyway.
Old 09-02-2013, 01:39 PM   #5
Rewards Points: 268
I will have him look at the fan control. I told him earlier to get the numbers off the relay and call me back. I may have one. If I do, I can get there in about 1/2 hour.
Old 09-02-2013, 01:41 PM   #6
Hvac Pro
yuri's Avatar
Yeah, even if the button is not pushed in they can fail ON. only way 2 know is 2 B there and remove the wire at the control 2 know 4 sure.
Old 09-02-2013, 01:51 PM   #7
Rewards Points: 268
Thanks, Im just going over there. Its only about 15? miles. Im taking some parts and the computer, so I can check back.
Old 09-02-2013, 04:50 PM   #8
Rewards Points: 268
Finally back. Replaced the relay. Let it run through several on/off cycles and it is all good. Thank you very much.
Old 09-02-2013, 05:06 PM   #9
Hvac Pro
yuri's Avatar
Yur Welcome.
Humidifier for Carrier Infinity 96 system rvmeush HVAC 1 09-19-2012 07:16 AM
How to check secondary heat exchanger on Carrier SXC? Vaandjay HVAC 3 12-19-2010 12:27 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-17-2008 12:25 AM
