Carrier 58 MCB Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 01:40 PM   #1
Carrier 58 MCB gas furnace
Have a carrier furnace that starts blowing cold air. Replaced thermostat but no change. Every time repair man comes finds no problem heat works. Found that killing breaker to furnace allows heat to work again. tired of doing that. what should I check and where next time cold air starts
lojak37 is offline   Reply With Quote
Old 01-20-2012, 02:15 PM   #2
Houston204's Avatar
Rewards Points: 556
http://www.docs.hvacpartners.com/idc.../58mcb-4sm.pdf
Check the LED display on the furnace before resetting it next time.
Houston204 is offline   Reply With Quote
Old 01-20-2012, 02:18 PM   #3
MarginallyQualified
Rewards Points: 2,464
How long does it run before it shuts down?
How long after it shuts down before it'll start up again?
Old 01-20-2012, 03:54 PM   #4
I feel like a broken record, but try removing and cleaning the flame sensor........
harleyrider is offline   Reply With Quote
Old 01-20-2012, 04:22 PM   #5
how
Rewards Points: 1,070
Yeah Harley
Those drafts in the email box for copy & paste diagnostic responses make things easier..
how is online now   Reply With Quote
Old 01-24-2012, 10:05 PM   #6
Check the condensate drain for a blockage or slow drain.
dvenable is offline   Reply With Quote
Old 01-25-2012, 02:30 AM   #7
Like the man says "check the diagnostics before you break the power with the breaker"
Baldrick is offline   Reply With Quote
Carrier furnace problem. Pilot lights, no burner Donut HVAC 1 02-09-2011 09:07 PM
What are the carrier furnace codes? porang HVAC 1 01-24-2011 08:45 PM
Carrier furnace problems BigK75 HVAC 1 07-30-2009 06:16 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 10:48 AM
