Carrier 48SS018-060 Shuts Down When Cold Out - Pics Included - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 10:55 PM   #1
cham44's Avatar
Question
Carrier 48SS018-060 shuts down when cold out - pics included
I have a Carrier model 48SS018-060. It got down to 16 degrees F the night it went out. I did the reset procedure and it worked fine for 4 days and cut off again, LED is flashing 8 times = internal control fault according to the manual. I reset it again and its working so far. The fan does NOT blow cold air when it goes out. The orange ignitor wire was touching the yellow flame sensor wire so I took care of that with a quick reroute. The guy who came out last year when my mom lived here told her that the burner was rusting and would need replacing soon. Of course that is what he told a woman so I take that with a grain of salt. It didn't look rusted to me but I didn't remove it and look inside of it. Besides, the burners are only $15/each and I only have two so not a big deal. Here are some pics.
http://i839.photobucket.com/albums/z...o/overview.jpg
http://i839.photobucket.com/albums/z...ercloseup1.jpg
http://i839.photobucket.com/albums/z...ercloseup2.jpg
http://i839.photobucket.com/albums/z...cuitboard1.jpg
http://i839.photobucket.com/albums/z...cuitboard2.jpg
cham44 is offline   Reply With Quote
Old 02-14-2011, 02:57 AM   #2
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
Not sure why your furnace is doing what its doing but I would have the heat exchanger inspected. Rust is a good indicator that the heat exchanger may be in bad shape.
unicursalhex is offline   Reply With Quote
Old 02-14-2011, 05:15 AM   #3
An old Tradesmen
Rewards Points: 6,074
Your burners are rusting from the pics, and probably so is your heat exchanger.
Old 02-14-2011, 04:29 PM   #4
cham44's Avatar
I removed and cleaned the ignitor and flame sensor, reinstalled. Watched it startup a couple times. It lit no problem but I noticed that there appears to be a small flame between the 2 burners, yellow/blue then blue. I can't see back there but it would seem that there is a hole/crack back there. When they cool down I will get my handy extension mirror with LED attached and inspect it. But my question is would this cause the burners to not light occasionally? Or could I have installed the ignitor and/or flame sensor in such a manner that they interfere with the flow and cause this? They were just put in with screws, not like they were precision aligned or anything.
The heat exchanger shouldn't be too bad, my CO meter detected nothing and when the blower fan starts the flame does not change/jump/waver or change color.
Old 02-14-2011, 05:03 PM   #5
An old Tradesmen
That flame is from the cross overs, and it is suppose to be there. Its how one burner lights the other.
My CO meter can read as low as 1 part per million CO. And has found a fair number of cracked heat exchangers i n homes where there CO detector never went off.
Old 02-14-2011, 05:09 PM   #6
Just a thought
have you cut off about 1/2 inch of the spark wire and reinserted it to see if the wire is going bad on the control board end. this will sometimes cause the unit not to light and lockout. Also make sure there isn't anything on the pin before you reinsert the cable.
college A/C is offline   Reply With Quote
New SOD going brown? Pics Included. the punisher Landscaping & Lawn Care 18 07-04-2011 01:36 PM
Contractor problem with bathroom tiling - what are your thoughts? Pics included ck361 General DIY Discussions 21 05-18-2009 12:02 AM
BackYard needs Help ASAP!! Pics included fiji-fa5 Landscaping & Lawn Care 20 04-29-2009 09:00 PM
blower fan not coming on (pics included) TitanTn HVAC 6 02-16-2009 09:48 PM
Need suggestions for Painting my game room... PICS included. jaysen Interior Decorating 8 11-13-2008 11:45 AM
