Carrier #48ss018-060,208/230-1-60 Package - HVAC - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 11:57 AM   #1
Carrier #48ss018-060,208/230-1-60 package
Flex gas line getting hot enough to melt plastic coating,where would this short start from?
grandpa3055 is offline   Reply With Quote
Old 02-24-2012, 04:18 PM   #2
HVAC Tech/ Browns Fan
Were is it getting hot at? Is it near gas valve?
Tator1076 is offline   Reply With Quote
Old 02-27-2012, 07:30 PM   #3
Carrier 48ss018-060 208/230-1-60
It's getting hot on the flex line & that abount 18 inches from the gas valve! I hope you can give me some direction!
Old 02-27-2012, 07:49 PM   #4
how
Rewards Points: 1,070
Pretty bizzare! Can you not feel along that line for where it's hottest to get a sense for the source of the heat?
If it's not hot now during the furnace cycle, is this a previously caused damage by something like a trouble light bulb pressing directly against the plastic covering?
how is offline   Reply With Quote
Old 02-27-2012, 08:08 PM   #5
Carrier 48ss018-060 208/230-160 package
That is so bizzard about that we could not find a hot spot,only the flex line was hot and stay hot for a few minutes.The system ran after we disconnect the hose.
Old 02-27-2012, 09:05 PM   #6
how
Wow... A furnace that runs without fuel! Maybe if you had just started the thread telling us about that we could have focused on a real problem.
Old 02-28-2012, 01:23 PM   #7
That is odd. Maybe you need a service pro now.
Carrier error codes 48ss package jadams43 HVAC 0 01-24-2011 09:03 PM
How to check secondary heat exchanger on Carrier SXC? Vaandjay HVAC 3 12-19-2010 12:27 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-17-2008 12:25 AM
