Carrier 48hjd005 - HVAC - DIY Chatroom Home Improvement Forum
Old 08-03-2009, 05:43 PM   #1
Carrier 48hjd005
Hello everyone. I have an old Carrier 3-ton 48hjd005 unit. I noticed that the house was near 90 today and went out to have a look. It seems that when it first turns on the fan outside spins for about 5 seconds and then turns off. Any idea where I could look for the problem? Thanks!
Brian80 is offline   Reply With Quote
Old 08-03-2009, 06:30 PM   #2
newtech's Avatar
Rewards Points: 164
If you turn the power off and back on will it try again? It looks like the unit you have uses a CLO. Could be going off on high pressure, low pressure, or current. Also might be a bad CLO board. With-out guages and a meter???? http://www.xpedio.carrier.com/idc/gr...t/48hj-1si.pdf
newtech is offline   Reply With Quote
Product Advice - Trane or Carrier 99Problems HVAC 5 05-28-2009 06:23 PM
Carrier Infinity does not work with Control4 Thermostat o1o1o1o1 HVAC 1 02-27-2009 08:30 PM
Honeywell TrueSteam with Carrier Infinity Control Llama HVAC 1 02-19-2009 04:20 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-16-2008 11:25 PM
