Old 10-30-2009, 10:30 PM   #1
Default Carrier 48GS unit turns on, but no heat
hi everyone.
i'm very cold. lol
my husband is out to sea right now, and here i am alone with a broken hvac. i replaced the blower wheel in the blower motor, and put that back into the unit and hooked up all the wiring.
the unit turns on, i can hear it running, and hear a "clicking." there's no air coming out of the vents though.
could it possibly have to do with the ignition? could that be why the blower motor/wheel isn't kicking on and blowing air into the house?--because there's nothing ignited? how would i go about getting that to light?
the led on the circuit board isn't flashing. it's just on so it's not indicating any error. i had some concerns i might not have hooked up the motor right, but would the unit even turn on if the wiring was all off? in theory, if everything was hooked up right, shouldn't it just having do to with the heat source?
thanks for any advice you may have for me!
coldlady is offline   Reply With Quote
More On This Topic
In this clip, we are going to talk about the proper service procedure in order to diagnose remove and replace your vehicles starter solenoid. In this step we are going to talk about what starter solenoid is and the proper way to diagnose the command wire... Read More »
Pull the dash piece. Behind here you have the crossover for the stereo system. Let's move that out of the way. You have your air conditioning components. Here is your heater core. Access in the heater core wiring is right here in this harness. But... Read More »
There is a windshield cover inside the door that protects the cold, hot air coming in This can be peeled away. You locate the power window motor which is behind this panel right here and you trace the wires around and they are here. On this particular... Read More »
In this clip we're going to talk about the proper service procedure in order to diagnose, remove and replace you vehicles starter solenoid. In this step we're going to talk about the proper way to diagnose the wiring from the solenoid to the battery and... Read More »
How to Wire Car Accessories
How to Wire Car Accessories by Expert Village
We must access the wires by removing the dash panel and tapping into accessory 1, accessory 2, ignition 1 and ignition 2 and starter position. of course when tapping into those circuits, we must fuse protect the circuits being tapped into and must not... Read More »
Compatability question (cooling unit to heat pump) Common HVAC 2 10-28-2009 09:44 PM
new carrier heat pump furnace wont cool home wisjr HVAC 8 08-12-2009 02:23 PM
Carrier 58MCA Furnace – No Heat (Error 33) zerafah49 HVAC 1 12-10-2008 09:32 PM
Carrier outside package unit repair dtestin HVAC 0 11-10-2008 04:04 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 09:40 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
