Carrier 38YCC036 Heatpump Knocking - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 10:53 PM   #16
thermal-medics.com
good luck
Thats got to be annoying to hear that.
Post up what they find out with it.
The fella Beenthere had a interesting one about the fan blade cracked. The only other thing I was thinking was as the fan blade accelerates/decelerates it flexes a little. I know this becuse of course I have never put a condenser fan motor a little too low on the shaft, hahaha.
I did one and it flexed enough to tap on a pinch off tube below as it sped up. pulled the disconnect as fast as my a** could get to it. maybe on the decel it is flexing up and tapping the cage. dunno or maybe a set of wires hanging down. (around here it is the reversing wires tie wrapped to the cage that break in 120 degree heat and fall in)
thermal-medics is offline   Reply With Quote
Old 03-06-2012, 06:01 PM   #17
sktn77a's Avatar
Rewards Points: 390
REALLY annoying - especially as it's so cowardly as not to make the noise when I get outside to look at it!
The blades aren't cracked (checked that). I don't know if they can flex enought to hit the refrigerant pipe (I doubt it as the unit only makes the noise when the fan is going slowly - not enough air resistance to flex them that much) but who knows? Will post the solution if and when it gets fixed (the yokels out there in the mountains only work weekdays, and we only go up there at weekends).
sktn77a is offline   Reply With Quote
Old 03-20-2012, 04:07 PM   #18
sktn77a's Avatar
Rewards Points: 390
Update!
Well, turns out is was the condenser fan motor making that noise. When it starts up and slows down, it makes a metallic clanking noise that goes away when it gets up to speed or stops. The AC guy said the motor is going out and offered to replace it but also said it probably has a year or two left in it yet. I'm holding off in case anything else goes wrong, possibly making a changeout the more effective route.
Thanks to all for your help.
Keith
Carrier heatpump, when in AC the blower is not turning off metalmover HVAC 25 09-21-2011 07:55 AM
Carrier Heatpump marriedmanw HVAC 3 01-03-2011 11:11 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Carrier Infinity HeatPump code 46 SeanWhite HVAC 1 07-31-2008 08:48 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-17-2008 12:25 AM
