Carrier 38ycc Compressor Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 05:28 PM   #16
Sein just a FYI...compressors that young don't go out for no reason. Something killed it. Ask for a leak check before committing to a new compressor. A new evap coil(if it leaks),burn out clean up and new compressor will be expensive and have a 1 year warranty. A new system will have a 10 year warranty. While it's true a system can be fixed instead of replaced often times it just doesn't make financial sense to do so. Get ALL the options before making the decision.
The Following 2 Users Say Thank You to Marty S. For This Useful Post:
ben's plumbing (07-07-2012), Sein (07-08-2012)
Old 07-09-2012, 11:12 AM   #17
Thanks, Marty! I am getting a replacement compressor installed , as opposed to getting a new system which is significantly more expensive and I don't plan on living in this house for more than a couple of years.... I did insist on a leak check, though the tech guy did say this didn't look like a refrigerant issue... he did say the electrical continuity tests passed ok, but the compressor locks up on starting ... I'm wondering if this is maybe a mechanical failure ?
Sein is offline   Reply With Quote
Old 07-10-2012, 04:50 AM   #18
HVAC Contractor
Rewards Points: 316
Be SURE they check for acid levels. Grounded compressors almost always result in some level of burnout. They should certainly install a liquid line drier, and if the level is high enough they should also install a suction line drier. We also use Acid-Away in addition to the driers, and I cannot recall the last time we had a failure after a compressor install (other than one that was DOA after running for about 4 minutes - boy did that ever tick me off!!)
scottmcd9999 is offline   Reply With Quote
The Following User Says Thank You to scottmcd9999 For This Useful Post:
Sein (07-10-2012)
Carrier 38YCC fan doesn't shut off..water leakage MercyMoi HVAC 3 03-12-2012 06:02 PM
carrier 38ycc heat pump blowing fuses headhunter89 HVAC 1 06-20-2011 06:45 PM
Carrier 38ycc no compressor start Yerfdog HVAC 4 06-03-2011 10:08 AM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 12:52 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-16-2008 11:25 PM
