Carbon Build Up On Nozzle - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 06:22 PM   #1
Question
carbon build up on nozzle
I have a 16 year old Beckett oil burner. I have the problem of reocurring carbon build up around the nozzle tip and igniters. This problem causes the furnace to "trip" and cleaning of the nozzle and igniters is required to get it to fire back up. I have replaced the nozzle (75/70B) but does not seem to effect this bulid up. I have also recently replaced the oil filters ; there are two for some reason, one below the outside tank and one right before the furnace.
zuni97 is offline   Reply With Quote
Old 01-17-2009, 06:28 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Ayuh,... Sounds like it's running Rich,...
Call a Tech,+ have them meter the air/ fuel ratio...
Without the meter, it really can't be done properly...
Bondo is online now   Reply With Quote
Old 01-17-2009, 06:51 PM   #3
Thanks for the advice
Old 01-18-2009, 07:35 AM   #4
tk03's Avatar
Rewards Points: 150
I agree with the other post but the adjustment must also be checked. Beckett calls this the "Z" dimension. If this problem has just occurred when the weather got really cold it could just be a cold oil issue.
tk03 is offline   Reply With Quote
Old 01-18-2009, 12:04 PM   #5
It has happened with much more frequency with this bitter cold snap. It was also suggested to me that I might want to replace the oil pump screen. Any opinions? I do have an outside tank. Should I add any additives?
Old 01-18-2009, 04:12 PM   #6
Bondo's Avatar
Ayuh,..
It happens more often because it's running more hours,... Running Rich for more hours...
With 2 filters I wouldn't be too worried about the screen,..
Your outside tank,... Do you buy #2 fuel, or #1 fuel,..??
#1 will not be a problem,..
If you have #2, call for a fill up with #1,...
That'll do more than any Additives you can buy...
It Still won't fix the fact that the burner is running Too Rich...
Old 01-19-2009, 01:56 AM   #7
are you replaceing the nozzle with the same one you took out or did you confirm from the rating plate that the correct nozzle was installedin the first place just something else to check
kennzz05 is offline   Reply With Quote
Old 01-20-2009, 07:59 PM   #8
Nozzles
I agree with Kennzz05, flame impingement could occur with the wrong nozzle. Always follow the rating plate. A .75 nozzle should roughly have your air open, somewheres between quarter and halfway open. if yours is open fully call a burner tech to set the air up for you.
coneage is offline   Reply With Quote
Old 01-20-2009, 08:02 PM   #9
Building and plumbing
USP45's Avatar
Rewards Points: 150
Call a tech. We used to set them by sighting a orange tip to the flame, but found nothing beats using a meter to set it.
USP45 is offline   Reply With Quote
Carbon Monoxide Kills TRUSTEDTRADESMEN General DIY Discussions 1 06-23-2008 07:52 AM
Sister floor joists or build support wall? Bcoleman6 Building & Construction 3 02-21-2008 01:06 PM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 06:52 PM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 04:39 PM
Cost to Build pallen Building & Construction 4 06-18-2006 11:43 PM
