Old 03-25-2010, 10:50 AM   #1
Capping a return vent
I am removing a wall between the master bedroom and spare room, can I just "cap off" a return vent in that wall or does it have to be rerouted? The master bedroom already has a return vent.
brilizbell is offline   Reply With Quote
Old 03-25-2010, 02:19 PM   #2
I am planning on taking out a wall between our master bedroom and a spare room. It has a return air vent in it, can I just cap it off or do I need to reroute? The master bedroom already has a return vent in it.
2 threads on same issue merged
Moderator
Old 03-25-2010, 04:21 PM   #3
An old Tradesmen
Since most homes are short on return to begin with. Its doubtful your system has enough return now.
So when you remove that wall. Either reroute the return, or have it as a floor return in the middle of the rooms.
Old 03-26-2010, 10:00 AM   #4
I do know that we have a return in everyroom of the house, the bedrooms have one on floor, then one directly above about three inches from ceiling. Didn't they recommend high returns instead of floor location some years back? I think this is a previous owners attempt at that.
Old 03-26-2010, 10:27 AM   #5
An old Tradesmen
High and low returns don't do what people think they do.
While you may have a return in every room. With the exception of the kitchen and bathrooms.
Doubtful you have near enough. Since often. Someone just put them in because they were told to. But never checked the amount of return they were getting.
A wall or floor return doesn't always return as much as a person thinks, because the rest of the duct is restrictive. So eliminating one. Just makes the return system as a whole more resistive yet.
Check the temp difference between your closest supply and return to the furnace. See how high it is.
Tags
return air, tear down wall
Vent Bath Exhaust to Cold Air Return? brandon272 HVAC 12 03-28-2011 06:11 AM
Converting a return into a normal vent? Red Squirrel HVAC 0 11-04-2009 09:58 PM
Return air vent question sidewayzisbest HVAC 5 05-10-2009 04:39 PM
Do I need a HVAC return vent in basement? westing HVAC 12 01-28-2009 01:09 PM
Running network wiring in a cold air return vent? mcvane Electrical 26 04-19-2007 08:52 AM
