Capping/removing Gas Flue - HVAC - DIY Chatroom Home Improvement Forum
Old 04-04-2009, 08:18 PM   #1
Capping/removing gas flue
I removed an old gas space heater in my finished attic. I plan sealing up the wall and abandoning the old flue. Can I keep the flue in place and seal the top on the roof (to be moisture/waterproof)? Or do I need to remove the flue completely and seal the resulting hole in the roof? What would be the best way to do this?
destroyer427 is offline   Reply With Quote
Old 04-04-2009, 08:25 PM   #2
HVAC / Plumbing
You can leave it.. If it has a cap .. you shouldn't have any moisture problems.. You may cause problems trying to remove & seal hole in roof.. Seal it where it connected to heater or it will remove heat/ cool from that area of the home...
kenmac is offline   Reply With Quote
Old 04-04-2009, 08:44 PM   #3
When it rains heavily the bottom wall plate looks a bit wet, as a few rain drops have gotten through. Perhaps the issue is more specific to the current state of the cap on top, I'll get on the roof and take a picture of it
Old 04-04-2009, 09:27 PM   #4
HVAC / Plumbing
If you feel confortable with removing the vent & patching the hole..Go for it
Old 04-05-2009, 07:43 AM   #5
disconnect or cut the pipe close to the interior portion of the roof,put a new cap on it and presto attic ventilator
kennzz05 is offline   Reply With Quote
Old 04-05-2009, 09:23 AM   #6
An old Tradesmen
Rewards Points: 6,498
In general, thats a good idea.
Make sure you seal all access to the attic knee wall area though.
And, if the chimney vent is above your roof line. make sure that it won't draw in hot air from ridge vents, instead of cooler air from sofit vents.
Old 04-05-2009, 12:35 PM   #7
Idea
Good Idea Kennzz05.
SULTINI is offline   Reply With Quote
New Flue Liner Regulations-NY Ron6519 HVAC 5 11-27-2007 11:28 AM
Chimney Flue Hole leezarrd Roofing/Siding 11 11-13-2007 05:18 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 11:28 AM
Flue Gas Piping and Proper Drafting DK75 General DIY Discussions 2 01-12-2006 10:04 AM
Wood Burning FP needs flue extension Renee Building & Construction 1 08-29-2005 06:26 AM
