Capacitor Size Differences - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 04:24 PM   #16
I would change the cap out when your back there, but to be honest if the comp seems to start/run ok it wouldnt really bother me to have a cap that was 5 microfarads off from original, hell its probly still within tolerance of the original, if you were to test it on a meter, they are typically rated +/- 10%. I would rather see 40 (slightly higher) than 30(lower) if it were me.
Brick is offline   Reply With Quote
Old 08-01-2011, 05:58 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 92
Originally Posted by Doc Holliday View Post
I understand both the Copeland Scroll book (which I've never seen) and the stated info on a motor concerning it's respective cap (which I see daily) but if all the data was sun dried off of the unit, the compressor and the condenser fan motor as well as the capacitor and you had no idea what make the unit was, what then?
New unit?
If it ran for quite a few yrs with the wrong cap then it probably is ready to die shortly anyway and you will be selling a new unit. Odds of the previous tech being that dumb or negligent and you running into it are probably less than 1%.
Old 08-01-2011, 06:08 PM   #18
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by beenthere View Post
I don't run into too many 1940s units, so I'm not sure what I would do.
I just thought that there was a formula for figuring out the correct size cap for a motor. Just curious but no worries, I always call the supply house with the unit model numbers to find out.
Doc Holliday is offline   Reply With Quote
Old 08-01-2011, 06:30 PM   #19
An old Tradesmen
Rewards Points: 7,730
There is a formula. I don't remember it anymore, as I recall though. You need to know the RPM and displacement of the compressor though.
Old 08-01-2011, 06:38 PM   #20
Hvac Pro
yuri's Avatar
Rewards Points: 92
pie/R/squared
Differences between these light switches? argh Electrical 11 11-02-2010 09:12 PM
Questions on tiling a floor abefroman Flooring 25 07-28-2010 10:18 PM
Home showers' differences? MagicalHome Appliances 0 07-06-2010 11:19 AM
Differences in Graco Lines wiz561 Painting 1 03-07-2010 08:19 AM
Differences between SW Duration, Superpaint and Cashmere? Autumnknight Painting 2 03-08-2007 08:55 PM
