Capacitor ---round Vs. Oval - HVAC - DIY Chatroom Home Improvement Forum
Old 06-09-2009, 03:42 PM   #1
Capacitor ---round vs. oval
Hey all...
Well I ordered the replacement capacitors and just got them in the mail...one question...they are oval and the ones i am replacing are round.
Does it make a difference?
ashton is offline   Reply With Quote
Old 06-09-2009, 03:55 PM   #2
30 year tech
hvac122's Avatar
No difference except the shape.
hvac122 is offline   Reply With Quote
Old 06-09-2009, 06:35 PM   #3
An old Tradesmen
Rewards Points: 7,410
As above.
Old 06-09-2009, 07:32 PM   #4
An oval shape dissipates internally generated heat better, assuming the same enclosed volume, because an oval has more surface area than a circle.
Maybe this shape change was for that purpose, maybe not.
Check it before installing, at least for a short.
Old 06-10-2009, 07:32 AM   #5
Yes, the oval ones taste better.
Good pics showing the specs match. You are good to go.
dac122 is offline   Reply With Quote
Old 06-15-2009, 05:51 PM   #6
ok
oval or round as long as they are the same specs your fine.
queenie is offline   Reply With Quote
Old 06-15-2009, 06:09 PM   #7
yeah, the round ones let the electrons flow betterjust like round ducts
allows better airflow.
Actually Yoyzit, the round ones take up less space and that allows for a smaller control compartment. All about cost.
hvaclover is offline   Reply With Quote
Old 06-15-2009, 07:40 PM   #8
HVAC / Plumbing
for mounting purposes . I like round... If they flow better electrons. That's just a +
kenmac is offline   Reply With Quote
Old 06-15-2009, 09:15 PM   #9
Home Air Direct's Avatar
Originally Posted by hvaclover View Post
yeah, the round ones let the electrons flow betterjust like round ducts allows better airflow.
I see it's comedy night at the forum
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 06-15-2009, 09:48 PM   #10
No! Round is better because the electron go aROUND the nucleus
SEE?
Old 06-16-2009, 12:26 PM   #11
HVAC / Plumbing
SEE?
The things you seem to come up with...
Old 06-16-2009, 12:33 PM   #12
I think somebody is one proton short of an electrically neutral atom.
Old 06-16-2009, 01:41 PM   #13
ya wanna see my formula for Cold Fusion power?
Old 06-16-2009, 02:20 PM   #14
Mold!! Let's kill it!
Rewards Points: 2,012
Yes, but those electrons travel in an oval orbit............... OVAL!!
Old 06-16-2009, 02:43 PM   #15
Wrong. that is just perspective that makes it appear oval.
see? this is a how a single electron in it's orbit if viewed from above LOOKS.
The broken line represents the electron's circular (round) path as it moves along it's orbit. ROUND RULES!
Oval rug embedded in Hardwood floor wickedcid Flooring 7 01-22-2009 04:29 PM
